physical design
Hello..
PhysDesignRules:367 - The signal <r_Rx_Serial0_IBUF> is incomplete. The
signal does not drive any load pins in the design.
iam using spartan 3e fpga in xilinx ise when i try to implement uart communication i would have taken uartrx and uarttx module those two i inluded in one main module but when try to pass the inputs to the uartrx iam gettin the above warning ..
Re: physical design
At which process did you get this error?
If it is in Implementation, you can open the post-synthesis design in ISE with "Technology Schematic" or in Planahead and check if the signal mentioned in the error message drives any load. If it does drive nothing, check your code to see if there is any mistake that leads to incorrect connection.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Re: physical design
iam getting the warning message in map section.
i think nothing wrong in my code i make correct connectins to each other
Re: physical design
Can you check the post-synthesis schematic in ISE "Technology Schematic" or in Planahead?
-vivian
Re: physical design
i opened and i checked the rx pin is not drive by any source .
what should i do to resolve this physical design issues .
what my be the issues for this rx pin is not connecting to desired pin location
Re: physical design
Can you post the screenshot of the schematic and the related code snippet?
-vivian
