programming Basys2 using AHDL
I have a Digilent Basys2 board, which have FPGA Spartan3E.  I installed ISE Webpack 14.7 and when I tried to perform the implementation, I experienced with this the licensing issue.  Would you please advise
I recently bought the Basys2 using FPGA XC3S100E. After installing the ISE Degisn Suite 14.7 DVD, I have this error when running the implementation
C:\FPGA\Digilent\Software\Xilinx.LIC;C:\License\Hunter-PC.LIC;C:/.Xilinx\Xilinx.
lic;C:\Xilinx\14.7\ISE_DS\ISE\/coregen/core_licenses\Xilinx.lic;C:\Xilinx\14.7\I
SE_DS\ISE\/coregen/core_licenses\XilinxFree.lic;
FLEXnet Licensing error:-5,357
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
Map:258 - A problem was encountered attempting to get the license for this
architecture.
Design Summary
Number of errors : 1
Number of warnings : 0
File 'c:/FPGA/Digilent/Example1/swled/implement/ver1/rev1/map.ncd' does not exist.
MAP failed.
Implementation ver1->rev1 Failed.
Please advise if you have a fix for this
Daniel
Re: programming Basys2 using AHDL
Hi @dannynvu
From the file attached I see that you dont have license for ISE, you need to generate ISE webpack license.
Deepika.
Thank you for your reply.  I download the new license from Xilinx as attached and it still cause the same error.
Hi @dannynvu
No, this license also does not have ISE features. Please generate the license following below steps
Open ISE, click on Help-->Obtain a License Key-->Get VIvado/ISE Webpack license.
Now generate ISE WEbpack license from your account.
Then load it using Load license option in Manage License tab of Xilinx License Configuration Manager.
Deepika.
Hello Deepika,
Can you take a look at the new license attached and advice.  the same error when I run the Implementation
Hi @dannynvu,
It seems Vivado webpack license.
Can you check if you have ISE webpack license in your account?
Arpan
@dannynvu,
Even this license does not have ISE Webpack feature.
Can you login to your product licensing account and see if you have the ISE Webpack license in either the "Create License" or "Manage License" tab?
Nupur
Hello Arpan and Nupur,
Here is what i see in my account license manager and create new license tab.
Danny
