project error
Hello, I want to ask a very simple question, I wrote a very simple program under vivado2018.2, but the synthesis failed, there is no error message, my program is no problem, the path is all in English, the user The name is also in English, the license has not expired, I want to know what the reason is.1.PNG
I attached my file , you can have a try.
Hi @weelcj ,
You set input a, output b, but assign a=b. The correct assignment is assign b=a.
Yang
Thanks,but it still not work
I can run synthesis successfully in my end, so what's your OS?Could you share your project or log file?Capture.PNG
my OS is win10,the run log file is " with args -log desi.vds -m64 -product Vivado -mode batch -messageDb vivado.pb -notrace -source desi.tcl
",and there are no error messages
Headache, the pot of the computer housekeeper, just turn it off.but still thank you
It's very interesting, could you provide the details? Maybe it can help others.
The reason why vivado synthesis has been reporting errors but not displaying error messages:
(1) There is a problem with the license file;
(2) The path has Chinese and the computer name is also Chinese;
(3) The firewall is blocked;
(4) For the sake of computer butler and other anti-virus software, turn them off.
