vinogradov_rus
register balancing/register retiming in Vivado
Hello, I've tried retiming in Vivado 2016 and found that it seems doesn't work at all =/
Here's simple example
module mult #(
    parameter BW = 32
    input clk       ,
    input [BW-1:0] a  ,
    input [BW-1:0] b  ,
    output [2*BW-1:0] rez
wire [2*BW-1:0]  w_prod;
reg  [2*BW-1:0]  rez0;
reg  [2*BW-1:0]  rez1;
reg  [2*BW-1:0]  rez2;
reg  [2*BW-1:0]  rez3;
reg  [2*BW-1:0]  rez4;
assign w_prod = a*b;
always @(posedge clk) begin
    rez0 <= w_prod;
    rez1 <= rez0;
    rez2 <= rez1;
    rez3 <= rez2;
    rez4 <= rez3;
end
assign rez = rez4;
endmodule
I see the same structure after synthesis - 4 one to another connected DSP units with no register between them. No matter if I set -retiming true or not. And the same timings result.
So how to enable retiming and resource sharing in Vivado 2016?
syedz
@vinogradov_rus,
With retiming option enabled in Vivado synthesis. I see the following INFO message in the log file.
INFO: [Synth 8-5816] Retiming module `mult`
Effective logic levels is 0, the effective logic levels of whole design is 0
Skipping retiming for this module
INFO: [Synth 8-5816] Retiming module `mult' done
FYI: Logic levels means the levels of combinational logic between two timing end points. E.g. a LUT is one level of logic. If there are 3 LUTs between two FFs, we say there are three logic levels.
--Syed
vinogradov_rus
And what about retiming between DSP slices?
vinogradov_rus
Another example
I've provided 4 D-triggers after long combination logic, enabled Retiming on synthesis and Retiming on Place&Route
So know I see 7Level logic (which occures timing violation) and this 7level logic connected to SRL shifter. So Vivado didn't use it for retiming.
Seems that retiming doesn't work in Vivado and thats the reason why Xilinx keep silience about this feature.
syedz
@vinogradov_rus,
Can you please share the new test case?
--Syed
