safe_implementation does not work
Hello all,
I have 2 hdl with one fsm each one. In xst options, I have safe implementation switched to yes. In hdl code, I wrote this lines in both codes.
(* SAFE_IMPLEMENTATION="YES", SAFE_RECOVERY_STATE = "IDLE" *)
reg [`STATE_WIDTH-1:0] state, next_state;
in synthesis report of the first hdl, I have this
Set property "SAFE_IMPLEMENTATION = YES" for signal <state>.
Set property "SAFE_RECOVERY_STATE = 22" for signal <state>.
Set property "SAFE_IMPLEMENTATION = YES" for signal <next_state>.
Set property "SAFE_RECOVERY_STATE = 22" for signal <next_state>.
| States             | 15                                             |
| Transitions        | 64                                             |
| Inputs             | 27                                             |
| Outputs            | 20                                             |
| Clock              | CLOCK (rising_edge)                            |
| Reset              | RESET (positive)                               |
| Reset type         | synchronous                                    |
| Reset State        | 010110                                         |
| Recovery State     | 010110                                         |
| Encoding           | auto                                           |
| Implementation     | BRAM                                           |
So, this FSM has been implemented with safe_implementation, but in the second one, I have this in synthesis report.
| States             | 15                                             |
| Transitions        | 79                                             |
| Inputs             | 31                                             |
| Outputs            | 20                                             |
| Encoding           | auto                                           |
No mention to Recovery State.. so, this FSM has not been implemented safe_implementation. I don't know why because all propierties seems to be enabled for this mode... thanks in advance!
Re: safe_implementation does not work
I've notice there is a warning before module instantiation:
Xst:2144 - The value of attribute <SAFE_RECOVERY_STATE> (IDLE) does not match fsm state <state> size (6).
so, i've change the IDLE declaration to 6'b010110 and I have this
Xst:2144 - The value of attribute <SAFE_RECOVERY_STATE> (6'b010110) does not match fsm state <state> size (6).
I don't understand what the value does not match if they are the same width...
Thanks!
Hello all,
I still working with this issue... what reasons can avoid a safe implementation of a fsm in XST?
Thanks in advance!
@pablo_trujillo
Which device was targeted? If older than 6-Series, try to enable the new_parser and let us know the results.
Also, please share the FSM full code here for us to test the RTL at our end.
Anusheel
Helpful answer -> Give Kudos
I finally fixed the issue. I've notice that code didn't change from version that works correctly, so, the problem must been in top module. In this new code version, i've added a fsm in top. if I comment this fsm, XST sinthesize in safe mode the main fsm... i don't know why. So, I included a new module with the fsm that was in top, and then all fsm have been syntesized safely... Thanks for response :)
regards!
