signals name getting change after synthesis on vivado 2015.4
Hi All,
I have three modules as mentioned below,
top_module (it has 4 AXI DMA master engines), arbiter and AXI DMA slave module(MIG user interface). The top_module talking to the arbiter and arbiter talking to the MIG UI. I wanted to add the debug core for output AXI signals of top_module and output AXI signals of the arbiter. After synthesis I opened the schematic and marked required signals for debug from arbiter to MIG UI, while trying to add the top_module to arbiter signals I couldn't find the signals like AWVALID,AWREADY,WVALID,WREADY etc.
But signals are there with different names like mem_q[39:0],D[19:0] etc. The above mentioned AXI signals are may be declared as wire in the DMA engines not reg.
How to add these signals into ILA core. Please help me.
Re: signals name getting change after synthesis on vivado 2015.4
Hi @ramesh.d2015,
Can you try putting mark_debug in HDL?
Then use setup debug to add the debug signals.
Arpan
Hi @ramesh.d2015,
Arpan
Hi Arpan,
sure, I'll try with mark_debug in the HDL. I didn't try this so far.
Thank you very much, I'll get back to you asap.
-ramesh
Voyager
Voyager
Another thing to look at is the synthesis settings "flatten_hierarchy" , it may be set to something other than NONE.
Hi Arpan,
Its works perfectly!!!, though the signals are declared as wire in the design I could able to add those into debug core by mark_debug. Thank you very much.
-ramesh
