Visitor dinesh627
spartan 3an in system flash programming
sir
i wrote a vhdl code for simple counter. both test bench report and fpga implementation is fine but when i write vhdl code for structural programming using dflip flop . for that test bench report is fine but not working on spartan kit
Re: spartan 3an in system flash programming
Hi @dinesh627,
You will need to give more detail if you want help from the community. For example, why aren't you posting your code? Why aren't you explaining why you say it is not working (do you have an error in ISE, do you see an issue on board)?
Florent
Florent
Hi @dinesh627
Before dumping onto the board, did you check the functionality in Simulation (behavioral, post synthesis and implementation)?
Thanks,Vijay
Visitor dinesh627
entity updff is
port (rst,clk:in std_logic;
q,qb:inout std_logic_vector(3 downto 0));
end updff;
architecture Behavioral of updff is
component dff is
port(d,rst,clk: in std_logic;
q,qb: inout std_logic);
end component;
signal a,b,c,d,e,f,g,h,i,j : std_logic;
begin
a<=not q(0);
D1 : dff port map(a,rst,clk,q(0),qb(0));
b<=(q(0) xor q(1));
D2 : dff port map(b,rst,clk,q(1),qb(1));
c<= q(0) and q(1)and qb(2);
d<= qb(0) or qb(1);
e<= q(2) and d ;
j<= c or e;
D3 : dff port map(j,rst,clk,q(2),qb(2));
f<= qb(0) or qb(1) or qb(2);
g<= f and q(3);
h<= q(0) and q(1) and q(2) and qb(3);
i<=g or h;
D4 : dff port map(i,rst,clk,q(3),qb(3));
end Behavioral;
entity dff is
end dff;
architecture Behavioral of dff is
begin
process (clk, rst)
begin
if (rst='0') then
q<='0';
else
if(clk='1' and clk' event) then
if (d='0') then q<='0';
else q<='1';
end if;
end if;
end if;
end process;
qb<=not q;
end Behavioral;
Visitor dinesh627
NET "rst" LOC = "T9";
NET "CLK" LOC = "E12";
NET "q<3>" LOC = "W21";
NET "q<2>" LOC = "Y22";
NET "q<1>" LOC = "V20";
NET "q<0>" LOC = "V19";
Visitor dinesh627
bit file is generated. pin allocation is done. there is no error in simulation. pinout report of xilinx is okay. But in spartan 3an starter kit it is not working. and no error and no warning is showing. without using the component for the simple counter spartan 3 an is simulating. i have posted the code for counter using d_flip flop
Visitor dinesh627
Hello @florentw i have posted the code of counter using Dflipflop. Everything is okay before the dumping the code on spartan kit.
simulation test bench in producing the required output. ucf code is also posted. please tell if any.
Visitor dinesh627
please help
Hi @dinesh627,
As mentioned by @vijayak, did you check the post-implementation simulation? Could you show the waveforms of behavioral and post-implementation showing the behavior
Florent
Florent
Visitor dinesh627
Visitor dinesh627
sir this is my ucf file
Visitor dinesh627
Sir @florentw
this output should be reflected on fpga spartan 3an starter kit board. when i dump the code on board all four led glow. I am not getting the desired output as shown in test bench report.
@dinesh627,
Is it post-implementation simulation or behavioral? Please clarify
Florent
Visitor dinesh627
behavioral
Hi @dinesh627,
So please show the post-implementation simulation
Florent
Visitor dinesh627
@florentw
its a behavioral simulation
Visitor dinesh627
@florentw
how to get the post implementation simulation. as m working on Xilinx 14.7
Hi @dinesh627,
See these links:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/pp_p_process_generate_post_place_and_route_simulation_model.htm
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_4/ise_tutorial_ug695.pdf
Florent
Visitor dinesh627
@florentw
I already did this. generated ucf file.
Visitor dinesh627
Place and route
generated post simulation. there is no error there.
Hi @dinesh627,
-> please show the screenshot... (run the simulation!)
Florent
Visitor dinesh627
Hi @dinesh627
 Post PNR simulation:Capture.PNG
hemangd
Hi @dinesh627,
Please run the simulation.
Refer to UG695 p126 (Timing Simulation Using Xilinx ISim) and share the screenshot of the post implementation simulation waveform
Florent
Visitor dinesh627
@florentw
Thankyou for guiding me upto postsimulation result
here is the post simulation result
Visitor dinesh627
Visitor dinesh627
@florentw
simulation post place & route
Hi @dinesh627,
Thanks. Just a check: Do you have the same UCF between the working project and the non-working?
Florent
Visitor dinesh627
@florentw yes sir same working ucf
@dinesh627,
Then you should try to add an ILA to see what is going on in the HW
Florent
