srl_style dosen't affect the synthesize
I synthesized the following verilog code, but the shift registers are still used even with the attribute (* srl_style = "register" *).
what is wrong?
module srl_test(
    input wire [3:0] in,
    input wire clk,
    output reg [3:0] out
    (* srl_style = "register" *) reg [3:0] reg0;
    (* srl_style = "register" *) reg [3:0] reg1;
    (* srl_style = "register" *) reg [3:0] reg2;
    (* srl_style = "register" *) reg [3:0] reg3;
    always @( posedge clk )
    begin
     reg0 <= in;
     reg1 <= reg0;
     reg2 <= reg1;
     reg3 <= reg2;
     out <= reg3;
    end
endmodule
syedz
@elsayed.abdellah,
CR-996079 has been filed and the issue is reported to the factory.
--Syed
syedz
@elsayed.abdellah,
Checked in Vivado 2017.4 and lt doesnt seem to honour the attribute.
Looks like a bug to me, Will check with Factory and get back to you.
The example attached in the below link works as expected.
https://www.xilinx.com/support/answers/60799.html
--Syed
Yes, this is exactly what I got.
So, it was very confusing.
aher
This behavior is reported as bug and should be resolved in later build.
However as Syed pointed out, will you be able to use the example in AR as a workaround for now?
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
syedz
@elsayed.abdellah,
--Syed
Yes, the example in AR works well.
