12-01-2020 02:52 PM - edited 12-01-2020 02:53 PM
Trying to flip order of nibbles using a for loop but getting out of range when synthesizing in vivado, in contrast the vivado simulation says its in range.
Attached is my vivado.2020 project as a ZIP file...
Any ideas how to work around this problem?
Log:
Synth log:
Starting Synthesize : Time (s): cpu = 00:00:03 ; elapsed = 00:00:04 . Memory (MB): peak = 1021.457 ; gain = 0.000
INFO: [Synth 8-6157] synthesizing module 'testcase' [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:70]
Parameter max_cw bound to: 8 - type: integer
Parameter max_dw bound to: 64 - type: integer
Parameter max_sw bound to: 4 - type: integer
WARNING: [Synth 8-6896] loop limit (65536) exceeded inside initial block, initial block items will be ignored [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:85]
WARNING: [Synth 8-6896] event control except as first statement of always block inside initial block, initial block items will be ignored [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:93]
WARNING: [Synth 8-6896] wait statement is inside initial block, initial block items will be ignored [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:117]
INFO: [Synth 8-6157] synthesizing module 'synth_bug' [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:4]
INFO: [Synth 8-251] flip: flip[x] = data[0] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 3:0]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[1] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 7:4]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[2] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 11:8]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[3] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 15:12]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[4] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 19:16]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[5] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 23:20]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[6] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 27:24]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[7] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 31:28]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[8] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 35:32]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[9] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 39:36]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[10] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 43:40]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[11] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 47:44]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[12] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 51:48]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[13] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 55:52]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[14] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 59:56]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
INFO: [Synth 8-251] flip: flip[x] = data[15] = x (date=xxxxxxxxxxxxxxxx) [[j*4 + 4 = x:x]] [[i*4 + 4 = 63:60]] [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:41]
ERROR: [Synth 8-524] part-select [67:64] out of range of prefix 'data' [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:39]
ERROR: [Synth 8-6156] failed synthesizing module 'synth_bug' [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:4]
ERROR: [Synth 8-6156] failed synthesizing module 'testcase' [C:/Users/wmoore/Documents/fpga/zynq_pl/rtl/vlog/synth_bug/syn_testcase1.v:70]
12-01-2020 03:01 PM
Well, not the answer you're looking for, but you need to start out by recoding the 'for' loop.
In RTL design 'for' loops must have elaboration-time constants for the boundary conditions. Said in software-speak, all 'for' loops must be unrollable.
Vivado should have just emitted an error message on that before proceeding any further. Start with recoding for that problem before continuing.
Mark
12-01-2020 03:12 PM
Thanks. You were right. Now it passes synthesis:
// => flip :reverse order of nibbles of a word of a specified size
function [max_dw-1:0] nibble_flip(
input [max_sw-1:0] size,
input [max_dw-1:0] data
begin :nibble_flip_i
integer i;
integer j;
integer len;
reg [max_dw+4-1:0] tmp;
len = (size*2 > max_dw/4) ? (max_dw/4) : size*2;
tmp = {max_dw{1'b0}};
for(i=0; i < max_dw/4; i=i+1) begin
j = len-i-1;
if (i < len) begin
tmp[j*4 +:4] = data[i*4 +:4];
// Synthesis_translate off
$display("flip: flip[%0d] = data[%0d] = %0x (date=%x) [[j*4 + 4 = %0d:%0d]] [[i*4 + 4 = %0d:%0d]]",
j, i, tmp[j*4 +:4],
data,
j*4 + 4 -1,
j*4,
i*4 + 4 -1,
i*4
// Synthesis_translate on
end
end
nibble_flip = tmp[max_dw-1:0];
end endfunction
12-01-2020 03:17 PM
Just for completeness sake for anyone reading along, the loop was unrollable, because the max condition was based on a net variable (a function of input wire usr_csize) . This is not allowed. Your changes made the loop conditionals all elaboration-time constants, and things worked.
Mark
