Visitor doss
synthesis of ieee.math_in Vivado
I use a function to calculate some sinus values into the RAM for filter coefficients. THese are static values.
Vivado miss the ieee.math_real library. I have read the satic use is possible.
How can I set up correctly?
Voyager
Voyager
Re: synthesis of ieee.math_in Vivado
Hey @doss,
Something like this should do the trick:
library IEEE;
use IEEE.std_logic_1164.ALL;
use IEEE.numeric_std.ALL;
use IEEE.math_real.ALL;
constant AWIDTH : integer := 8; constant DWIDTH : integer := 32; constant MDEPTH : integer := 2**AWIDTH; type mem_t is array (0 to MDEPTH-1) of signed(DWIDTH-1 downto 0); function init_mem return mem_t is constant SCALE : real := 2**(real(DWIDTH-2)); constant STEP : real := 1.0/real(MDEPTH); variable mem : mem_t; begin for I in 0 to MDEPTH-1 loop mem(I) := to_signed(integer(
cos(2.0*MATH_PI*real(I)*STEP)*SCALE), DWIDTH); end loop; return mem; end; constant sin : mem_t := init_mem;
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
@doss "Vivado miss the ieee.math_real library."
 Vivado synthesis *DOES* suppport ieee.math_real for elaboration-time calculations, but unfortunately:
   - the online syntax checker in the VIvado editor mistakenly flags ieee.math_real as an error
   - some Xilinx documentation mistakenly claims ieee.math_real is unsupported
See these posts for more info and documentation links:
  https://forums.xilinx.com/t5/Synthesis/ieee-math-real-support-with-Vivado/m-p/749313#M20754
  https://forums.xilinx.com/t5/Synthesis/ieee-math-real-support-with-Vivado/m-p/749088#M20745
-Brian
