synthesis out-of-date
When synthesis is finished,it showed synthesis out-of-date again.
And from other similar question,I tried the command 'get_property NEEDS_REFRESH [get_runs <run_name>]' , it indeed returned 1.I have saved the design and make sure the verilog files in project are up-to-date. I don't know why this is still happen.What should I do?
Hi @yinglu2 ,
  You can click the details to find what results in it .
  When running synthesis , aviod modifying your sources.
Yang
Hi @yinglu2 ,
Have a look into this thread. https://forums.xilinx.com/t5/Implementation/synthesis-and-implementation-out-of-date/td-p/456968
It may help you out.
hemangd
Hi @yinglu2 ,
Yang
as yangc mentioned, the best way is by clicking the details button.
sometimes it is just the file order but it is better to make sure.
if u c that u have a file changed that is not important or if it is only a file order issue the press the force up to date button.
Hi @yinglu2 ,
Do you have further queries on it?
Else, close the thread by marking it as accepted solution.
hemangd
