system verilog packages - synthesis
I am trying to synthesize a design that contains system verilog packages and vivado doesn't seem to like this.
for the sake of simplicity i tried grabbing a simple system verilog  package of the net:
package definitions;
typedef enum bit [1:0]{ADD, SUB, MUL} opcodes_t;
typedef struct{
logic [31:0] a, b;
opcodes_t opcode;
} instruction_t;
function automatic [31:0] multiplier(input [31:0] a, b);
return a*b;
endfunction
function void fun( input [31:0] result );
$display("result = %d",result);
endfunction
endpackage
but even this gives errors when on the line that declares the package???
So my question is this: Does vivado allow you to use system verilog packages??
i am using Vivado 16.2
Guide
Guide
Re: system verilog packages - synthesis
Vivado definitely supports packages - both for Synthesis and simulation.
Are you sure that you have the file type defined correctly. Normally it should recognize the .sv suffix as a SystemVerilog file, but you can be sure by selecting the file in the Sources window and looking at the Type field in the General tab in the Source File Properties window
Or you can use the Tcl command
get_property FILE_TYPE [get_files definition.sv]
It should be set to SystemVerilog (and not, say, Verilog).
Avrum
@mreisterextron I have definitely implemented designs with systemverilog packages and they work well. Without seeing your full setup it's difficult to see what the problem is.
@mreisterextron
As already mentioned in above posts, Vivado supports SystemVerilog packages and tool should be able to compile it.
Make sure there are no other definition/name conflicts coming for the mentioned package. Also, can you share these SystemVerilog files for us to reproduce the same at our end?
Anusheel
Helpful answer -> Give Kudos
