Visitor weixie
systhesis process, Mapping error
Dear all,
we use the system generator to complie the xinlinx model to "ini" file.
However, when the compiling run to the mapping process, a RTI Build error accoured and shows the mapping was not successful.
The screenshot is enclosed also, when you are available, it will be appreciate if we can get some hint about this error.
we use the same Licen 2015, it works compeletel, from this year, it has this error.
The licence we purchased is also enclosed.
Thank you in advance.
Re: systhesis process, Mapping error
@weixie,
Thanks for sharing the files. I see that you have ISE_Webpack (Free) license which can only be used with limited devices.
Error message:
From License:
The device xc5vsx95t is not supported with webpack license hence you are seeing this error message.
Please check page number 8 in below release notes of ISE 14.7 to know the devices supported with webpack license.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
--Syed
@weixie,
Can you post your license file(Xilinx.lic) here?
Which version of Vivado are you using?
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
@weixie,
Can you please share the report file containing the complete error message?
Your description to the query is not clear. Can you please elaborate more?
Also check if the information mentioned in the following AR helps:
http://www.xilinx.com/support/answers/33770.html
--Syed
Visitor weixie
@syedz
here is the file which includes all the error information.
The file is " map " format, it can not be loaded.
So i change to " text " format, after downloading, could you change to " map " format then open it.
Thank you.
Visitor weixie
@nupurs
the licence file is enclosed, i change the format from "lic" to "text". after download the file, please change back to the format " lic "
The vivado version, i am not sure which version i used. how could i confirm it ?
Thank you.
@weixie,
Error message:
From License:
--Syed
Visitor weixie
@syedz
First, thank you for your support.
It seems that i did not generate the right Licence file.
Here is the screenshot of our Licence account, could you help us to confirm if we need to purchase a new licence or not ?
Visitor weixie
@syedz
Or, from your suggestions, which Licence should we purchase ?
could you share the details infomation of this licence with me ?
Thank you very much.
