Voyager
Voyager
use of std_logic_arith in UG901
I've noticed some sections of UG901 is correctly the using numeric_std package in the IEEE library but other sections of UG901 are using deprecated packages from Synopsys squatting in the IEEE library, viz.:  std_logic_arith, std_logic_unsigned.
For example, the 32-Bit Dynamic Shift Registers Coding Example uses std_logic_unsigned, while the 8-Tap Even Symmetric Systolic FIR filter uses numeric_std.
I assume this would simple enough to address in the next release of UG901.
Mike
Scholar richardhead
Re: use of std_logic_arith in UG901
std_logic_arith/signed/unsiged were never standard in the first place, so cannot become deprecated. They became a defacto standard.
Some designers still insist on using them, and Xilinx has historically been like microsoft when it comes to VHDL standards - they'll just do their own thing and just ignore everyone else.
So now they have plenty of legacy documentation/code using non-standard VHDL. It doesnt really matter, as the final implementation will still match.
I agree, it will not help eradicate their use, but it's here to stay. VHDL 2008 defined standard packages numeric_std_unsigned and numeric_std_signed, which are basically identical to std_logic_unsigned/signed, so standards pedants have already lost.
Scholar richardhead
Voyager
Voyager
Ah, thanks.  Learned something...hadn't realized that.
Mike
Scholar richardhead
I tell a lie, numeric_std_signed doesnt exist. Only numeric_std_unsigned is part of the standard.
