Visitor arash_azizi
using DSP slices fo 16-bit fixed-point addition
I want to use the DSP slices for 16-bit fixed-point addition in Vivado HLS. How can I force the Vivado to use DPS slices instead of the LUTs? or how can I use the resource directive to force the tool to use the DSP slices?
thanks,
 Here is my test code:
#include "ap_fixed.h"
typedef ap_fixed<16, 8> data_t;
void add(data_t inA, data_t inB, data_t *out)
data_t temp;
temp=inA+inB;
*out=temp;
Re: using DSP slices fo 16-bit fixed-point addition
It should infer by default . check this ARs as well
https://www.xilinx.com/support/answers/45518.html
check the synthesis
Thanks and Regards
Balkrishan
