Observer townsend
using two concatenated sources for one module argument
'sorry, but I'm a newbie here and I probably haven't worded things appropraitely in the subject line, but that's the best description I could come up with. Suppose I have a module and one of its input arguments is an eight bit value, but I use it in an application where the eight bit value I want to include there is comming from two four bit items. i.e. the module argument is expected to be, say, a byte X which is wire[7:0], but I have two separate nybles, A and B that are both wire[3:0]. How would I include these two arguments (say A is the MSNyble and B is the LSNyble) to represent the "byte" argument. What is the correct syntax to concatenate A and B to represent the argument X when I use the module?
-gt-
Teacher xilinxacct
Re: using two concatenated sources for one module argument
@townsend
Yes, the { } are the concatination operator... you don't have to use it in conjunction with the assign... anywhere, there is syntactically correct, sould be fine.
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
Teacher xilinxacct
@townsend
I think this is what you are looking for....
assign w_CAT = {r_VAL_1, r_VAL_2};
Hope that helps
Observer townsend
Does verilog allow that notation to be used anonomously, or does it have to ba named? In other words, can I toss just the "{r_VAL_1, r_VAL_2}" right into the place where I want the concatenated result (i.e. in the argument list of the module when I invoke it) or do I have to assign it to w_CAT to give it a name and put that into the argument list instead? It wouldbe nice if it works anonomously, otherwise I have to make up a new thing (i.e. w_CAT) to worry about.
-gt-
Teacher xilinxacct
@townsend
Hope that helps
