vivado 2016.3 synthesis problem
1)I only changed xdc file, but it needs me re-synthesis, how to force synthesis in vivado 2016.3.
2)I use vivado 2016.3 package my ip, it included the ip-catalog, and can add to the block design. But when I synthesis, cannot include my ip's source file. I manually add the my source file to the project, cannot associate to the block design.
Re: vivado 2016.3 synthesis problem
Hi @luoyanghero,
Go to design runs tab, right click on synth_1  and click on force up to date.
For 2nd query please create a new thread in design entry board to target correct audience :).
Arpan
Hi @luoyanghero,
Arpan
thanks a lot.
