12-16-2018 02:16 PM - edited 12-16-2018 02:23 PM
Hi all,
I have this error. Can any one suggest me as to how do i have solve it.
This is the part of code I get the error in
bram_write: process(clk, command_done) begin --meas_data(20 downto 10) <= cmd_duration; if (clk= '1') then if rst = '1' then s_m_bram_data <= x"00000000"; s_m_bram_addr <= x"00000000"; else s_m_bram_addr <= s_m_bram_addr; s_m_bram_data<= s_m_bram_data; end if; -- ---meas_data <= meas_data; offset_value <= offset_value; if cmd_mode = PDCM then meas_data(21 downto 10) <= meas_cmd_duration; meas_data(1 downto 0) <= "01"; if PDCM_cmd = DIS then meas_data(3 downto 2) <= "00"; offset_value <= "0000"; --s_m_bram_en <= '1'; elsif PDCM_cmd = PDIS then meas_data(3 downto 2) <= "10"; --s_m_bram_en <= '1'; offset_value <= "0000"; elsif PDCM_cmd = BRC then meas_data(3 downto 2) <= "01"; offset_value <= std_logic_vector(to_unsigned(five, offset_value'length)); else offset_value <= offset_value; end if; elsif cmd_mode = CRM then meas_data(21 downto 10) <= meas_cmd_duration; meas_data (1 downto 0) <= "10"; if crm_data(28 downto 25) /= "1100" and crm_data(28 downto 25) /= "0000" then --just write type meas_data(3 downto 2) <= "00"; offset_value <= std_logic_vector(to_unsigned(one, offset_value'length)); elsif crm_data(28 downto 25) = "1110" then --- actual long CRM code, chang into 1110 --- change to crn_10bydata meas_data(3 downto 2) <= "10"; offset_value <= std_logic_vector(to_unsigned(three, offset_value'length)); elsif crm_data(28 downto 25) = "0000" then offset_value <= std_logic_vector(to_unsigned(two, offset_value'length)); meas_data(3 downto 2) <= "01"; --else -- offset_value <= offset_value; end if; else meas_data(21 downto 10) <= meas_cmd_duration; meas_data (1 downto 0) <= "11"; end if; meas_cmd_duration <= meas_cmd_duration; if rising_edge(command_done) then if slave_read_trigger_i >"00" then wait_for_slave_response <= '1'; wait_for_cmd <= '1'; wait_for_meas <= '1'; command_done_mode <= slave_read_trigger_i; elsif slave_read_trigger_i ="00" then if cmd_mode= CRM then ---CRM wait_for_cmd <= '1'; wait_for_meas <= '1'; byte9to12 <= '1'; byte5to8 <= '1'; byte1to4 <= '1'; meas_cmd_duration <= cmd_duration; elsif cmd_mode= PDCM then ---PDCM wait_for_slave_response <= '0'; wait_for_cmd <= '0'; wait_for_meas <= '1'; meas_cmd_duration <= cmd_duration; end if; end if; end if; if i_slave_done = '1' then slave_done_mode <= '1'; meas_cmd_duration <= cmd_duration; end if; bram_crm_10bydata <= crm_10bydata; --s_m_bram_addr <= s_m_bram_addr; bram_1response <= i_slave_data(151 downto 120); bram_2response <= i_slave_data(119 downto 88); bram_3response <= i_slave_data(87 downto 56); bram_4response <= i_slave_data(55 downto 24); bram_5response <= x"00" & i_slave_data(23 downto 0); if slave_done_mode = '1' then if wait_for_slave_response = '1' and wait_for_cmd = '1' and wait_for_meas = '1' then-- and i_slave_done='0' then base_addr <= base_addr; bram_crm_10bydata <= crm_10bydata; bram_crm_data <= crm_data; bram_slave_response <= i_slave_data; --bram_response_count <= bram_response_count; if command_done_mode = "10" then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) + 2); --offset_value <= std_logic_vector(to_unsigned(two, offset_value'length)); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= i_slave_data(32 downto 1); s_m_bram_en <= '1'; wait_for_slave_response <= '0'; wait_for_cmd <= '1'; slave_done_mode <= '0'; --meas_cmd_duration <= cmd_duration; elsif command_done_mode = "01" then --bram_response_count <= bram_response_count; if bram_response_count = 5 then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) + bram_response_count); --offset_value <= std_logic_vector(to_unsigned(one, offset_value'length)); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= bram_1response; s_m_bram_en <= '1'; wait_for_slave_response <= '1'; bram_response_count <= bram_response_count-1; --wait_for_cmd <= '0'; --meas_cmd_duration <= cmd_duration; bram_response_count <= bram_response_count-1; elsif bram_response_count = 4 then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) + bram_response_count); --offset_value <= std_logic_vector(to_unsigned(one, offset_value'length)); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= bram_2response; s_m_bram_en <= '1'; wait_for_slave_response <= '1'; bram_response_count <= bram_response_count-1; --wait_for_cmd <= '0'; --meas_cmd_duration <= cmd_duration; bram_response_count <= bram_response_count-1; elsif bram_response_count = 3 then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) + bram_response_count); --offset_value <= std_logic_vector(to_unsigned(one, offset_value'length)); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= bram_3response; s_m_bram_en <= '1'; wait_for_slave_response <= '1'; --wait_for_cmd <= '0'; --meas_cmd_duration <= cmd_duration; bram_response_count <= bram_response_count-1; elsif bram_response_count = 2 then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) + bram_response_count); --offset_value <= std_logic_vector(to_unsigned(one, offset_value'length)); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= bram_4response; s_m_bram_en <= '1'; wait_for_slave_response <= '1'; --wait_for_cmd <= '0'; --meas_cmd_duration <= cmd_duration; bram_response_count <= bram_response_count-1; elsif bram_response_count = 1 then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) + bram_response_count); --offset_value <= std_logic_vector(to_unsigned(one, offset_value'length)); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= bram_5response; s_m_bram_en <= '1'; wait_for_slave_response <= '0'; wait_for_cmd <= '0'; --bram_response_count <= 5; --meas_cmd_duration <= cmd_duration; bram_response_count <= bram_response_count-1; slave_done_mode <= '0'; end if; --else --s_m_bram_addr <= s_m_bram_addr; end if; end if; elsif wait_for_slave_response = '0' and wait_for_cmd = '1' and wait_for_meas = '1' then --offset_value<= offset_value; --if command_done_mode = "10" then if crm_data(28 downto 25) /= "1110" then ----- change to 1110 s_m_bram_addr <=std_logic_vector(unsigned(base_addr) +1); --offset_value <= std_logic_vector(to_unsigned(one, offset_value'length)); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= bram_crm_data; s_m_bram_en <= '1'; wait_for_cmd <= '0'; elsif crm_data(28 downto 25)= "1110" then --- change to 1110 s_m_bram_addr <= base_addr; s_m_bram_data <= s_m_bram_data; --offset_value <= std_logic_vector(to_unsigned(three, offset_value'length)); if byte9to12 = '1' and byte5to8 = '1' and byte1to4 = '1' then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) +3); --base_addr <= base_addr; s_m_bram_data <= bram_crm_10bydata(96 downto 65); s_m_bram_en <= '1'; byte9to12 <= '0'; elsif byte9to12 = '0' and byte5to8 = '1' and byte1to4 = '1' then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) +2); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= bram_crm_10bydata(64 downto 33); s_m_bram_en <= '1'; byte5to8 <= '0'; elsif byte9to12 = '0' and byte5to8 = '0' and byte1to4 = '1' then s_m_bram_addr <= std_logic_vector(unsigned(base_addr) +1); --base_addr <= std_logic_vector(unsigned(base_addr) +2); s_m_bram_data <= bram_crm_10bydata(32 downto 1); s_m_bram_en <= '1'; byte1to4 <= '0'; wait_for_cmd <= '0'; else s_m_bram_data <= s_m_bram_data; s_m_bram_addr <= base_addr; s_m_bram_en <= '1'; end if; else s_m_bram_data <= s_m_bram_data; s_m_bram_addr <= base_addr; s_m_bram_en <= '1'; end if; -- elsif cmd_mode = PDCM then -- wait_for_cmd <= '0'; -- s_m_bram_addr <= base_addr; --end if; elsif wait_for_slave_response = '0' and wait_for_cmd = '0' and wait_for_meas = '1' then s_m_bram_addr <= base_addr; s_m_bram_data <= offset_value & meas_data(27 downto 0); s_m_bram_en <= '1'; wait_for_meas <= '0'; base_addr <= std_logic_vector(unsigned(base_addr) + unsigned(offset_value)+1); --meas_data(31 downto 28) <= offset_value; else s_m_bram_en <= '1'; s_m_bram_addr <= s_m_bram_addr; s_m_bram_data <= s_m_bram_data; --base_addr <= base_addr; end if; if s_m_bram_addr = not x"00000000" then s_m_bram_addr <= x"00000000"; end if; -- else -- --s_m_bram_en <= '0'; -- s_m_bram_addr <= s_m_bram_addr; -- s_m_bram_data <= s_m_bram_data; -- base_addr <= base_addr; --<= std_logic_vector(unsigned(base_addr) + unsigned(offset_value)+1); --end if; end if; end process; m_bram_en <= s_m_bram_en; m_bram_addr <= s_m_bram_addr; m_bram_data <= s_m_bram_data; m_bram_we <= x"F"; --s_m_bram_addr <= base_addr;
Kindly help me.
Thanks in advance
12-17-2018 01:29 AM
Hi @benaka,
Lets look into the errors first. I will try to explain one of the error from it.
Open synthesized design, and go to the net design_1/control_block_0/U0/byte1t04__0
And check that it has two drivers or not which are design_1_i/control_block_0/U0/byte1to4/Q & design_1_i/control_block_0/U0/byte1to4_reg/Q.
Then, you need to make necessary changes into your RTL source code to drive this net with only one driver.
Same, Do it for all the errors.
12-17-2018 03:21 AM - edited 12-17-2018 04:36 AM
Hi @hemangd,
I just found these, but I don't understand from where the second driver comes from. I have attached the screen shot for the same. Kindly let me know if its possible to clear without making any changes in the RTL level.. please
Thanks in advance
12-17-2018 03:42 AM
Hi @benaka,
Can you provide your archived project to reproduce this issue at my end for further debugging purpose?
I have sent you ezmove ftp test package through which you can provide your files.
12-17-2018 04:04 AM - edited 12-17-2018 04:05 AM
Hi @hemangd,
I was trying to change the RTL a bit, and still encountered a similar error for the same part of the code. I have sent the zip file for the same.
12-17-2018 07:44 AM - edited 12-17-2018 07:47 AM
Hi @hemangd,
So I managed to do a work around on the RTL level but now I have another issue.I first tried in the default way to generate the design, I got the timing warning and so tried the Flow_RunPhysOpt method, still I get the error.
can you kindly have a look at this. Attached is the timing report for the same.
