Visitor yyaodesy
vivado 2017.1 stuck when xdma ip core is synthesising
Dear All,
A problem encountered when I am synthesising my project which includes xdma core.
The Log information says:
Finished ROM, RAM, DSP and Shift Register Reporting
Finished Applying XDC Timing Constraints : Time (s): cpu = 00:04:48 ; elapsed = 00:05:17 . Memory (MB): peak = 1345.383 ; gain = 1011.527
Finished Timing Optimization : Time (s): cpu = 00:05:14 ; elapsed = 00:05:44 . Memory (MB): peak = 1534.066 ; gain = 1200.211
NDup read error: feof(1)
An unrecoverable error has occurred, synthesis cancelled.
TclStackFree: incorrect freePtr. Call out of sequence?
Also, I see a warning in Messages:
reset_run design_1_xdma_0_1_synth_1
[Vivado 12-1017] Problems encountered:
1. PID not specified
I am working with Vivado 2017.1 and 64-bits windows 7 Enterprise. This problem happened suddenly (I mean, it still worked well yesterday.....)
Thanks for any help in advance!
Visitor yyaodesy
Re: vivado 2017.1 stuck when xdma ip core is synthesising
Problems solved by updating vivado to up-to-date version, 2018.02
Does it mean we should keep our vivado version up-to-date all the time? :-(
Visitor yyaodesy
Also, I see some questions here:
https://forums.xilinx.com/t5/Synthesis/WARNING-Vivado-12-1017-Problems-encountered-1-PID-not-specified/m-p/761738#M21370
BTW, Is there any possibility that this happened because of some updates on the OS Windows 7?
Visitor yyaodesy
I have tried to:
1) disable anti-virus sw;
2) reset .db outputs and restart synthesis;
3) delete redundant logic and constraint (even I have tried to synthesis a design only an xdma core inside...)
Still of no use...
Is there anybody can give me some advice?
Visitor yyaodesy
