Observer flydrive
vivado synthesis internal signal naming
When you open a synthesized design all the internal nets and leaves have generated names which are of a consistent format, eg grabbing one from a recent synthesis, ser_num_q_reg[8]_i_1_n_3. It's obvious what the start of it is, bit 8 of the ser_num_q register and this signal is one of those in the logic which determines the next value for the FDRE at the end. However does the suffix "_i_1_n_3" follow a pattern which is documented somewhere or is this purely an internal implementation detail of vivado? If it is documented, where?
Re: vivado synthesis internal signal naming
Hi @flydrive,
Nets, pins, and cells are hierarchical objects. They will be located in the hierarchy as defined by the RTL code, as long as hierarchy isn't flattened.
Tool internally add suffix accordingly for analyzing. I don't thing there is any specific document available defining the suffix for the names.
But there are some general ones for example which tool adds for his understanding:
  1. Port inputs have the prefix "i_"
  2. Port outputs have the prefix "o_"
  3. Port bi-directional pins have the prefix "io_"
Raj
Hi @flydrive,
Raj
Observer flydrive
ok thanks for that - at least I didn't miss a piece of documentation and I'm not surprised this is just an internal implementation detail.
