what is the replacement of math_real library in vivado
recently I am going to update some of my design from ISE to vivado, but one of the issue is that the math_real libray is not support in vivado any more. As a result, some math functions, e.g. ceil(), cannot be recognized by vivado.
In stead of writing my own function in vhdl, does any one know some official replacement of those math function in library ?
Thanks a lot...
Tags (3)
Re: what is the replacement of math_real library in vivado
@wincle "one of the issue is that the math_real libray is not support in vivado any more"
I've used math_real recently (2016.3); for me it appeared to be working as described on page 191 of UG901 for calculating bit widths, counter preload values from real frequencies, and the like:
-Brian
Confusion might be :  http://www.xilinx.com/support/answers/52304.html
AR# 52304
Does Vivado Synthesis support IEEE MATH_REAL and PROPOSED package libraries?
Description
Does the Vivado Synthesis tool support IEEE MATH_REAL and IEEE PROPOSED package libraries?
Solution
Currently, the Vivado Synthesis tool does not support IEEE MATH_REAL and IEEE PROPOSED package libraries.
@geoffbarnes "Confusion might be :  http://www.xilinx.com/support/answers/52304.html"
That Answer Record is outdated regarding math_real support in Vivado.
I've asked Xilinx to fix AR52304 several times since 2013, but they just don't seem to care:
   https://forums.xilinx.com/t5/Synthesis/CR-Request-Update-UG901-Vivado-Synthesis-User-Guide-to-document/m-p/560689#M13344
-Brian
Yeah it seems to be outdated, but still listed as "active".
I guess to be fair, the intent of the AR might be to say : " you can't synthesize (dynamic) floating point logic using math_real".
But as written, it contradicts UG901.
