which is better? rst= VCC or rst= '1'
 hi
any difference that i use rst= VCC or rst= '1' (in the following code) ?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_unsigned.ALL;
entity seg_top is
	generic(Crystal_Value:integer:=50000000);
	Port (
				rst,GCLK	   :	in	std_logic;
				sel	           :	out	std_logic_vector(3 downto 0);
				leds		   :	out	std_logic_vector(0 to 7)
end seg_top;
architecture Behavioral of seg_top is
signal	VCC		        :	std_logic;
signal	Number 			:	integer range 0 to 9:=0;
	--	Definition of ROM type for
	--	7-Seg Display
type ROM is array (0 to 9) of std_logic_vector(0 to 7);
signal Seven_Segment : ROM:=(
			      x"fc",x"60",x"da",x"f2",x"66",
			      x"b6",x"be",x"e0",x"fe",x"e6");
begin
	VCC			<= '1';
	sel 			<= "0001";		--To select First 7segment for ever
	leds			<= Seven_Segment( Number );
process(GCLK,rst)
variable ctr: integer range 0 to Crystal_Value-1;
begin
	if rst= VCC then
		ctr:=0;
		Number <= 0;
	elsif rising_edge(GCLK) then
		if ctr < Crystal_Value - 1 then
			ctr:=ctr+1;
		else
			ctr:=0;
			if Number<9 then
				Number<=Number+1;
			else
				Number <= 0;
			end if;
		end if;
	end if;
end process;
end Behavioral;
Re: which is better? rst= VCC or rst= '1'
no difference as far as either simulation or synthesis is concerned. There is no reason to use VCC either. It would just be confusing. rst = 1 is perfectly fine.
library IEEE;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity uart is
		Port (
					clk 		   	: in	std_logic;
					RX_Pin			: in	std_logic;
					TX_Pin			: out	std_logic
end uart;
architecture simple of uart is
signal	TX_Reg		    	      :	std_logic_vector(7 downto 0);
signal	GND,VCC				      :	std_logic;
signal	Wr_En,Wr_En_D1,NewData	  :	std_logic;
signal	OneBit_Time_Reg		   :	integer range 0 to 5208;
signal	HalfBit_Time_Reg	   :	integer range 0 to 2604;
type	Uart_TX_Phase is (
							Standby,Start_Bit_TX,Data_TX,
							Stop_Bit_TX
signal	TX_State			:	Uart_TX_Phase;
type	Uart_RX_Phase is (
							Standby,Start_Bit_RX,Data_RX,
							Stop_Bit_RX
signal	RX_State		:	Uart_RX_Phase;
signal	RX_Reg		    :	std_logic_vector(7 downto 0);
begin
	 GND <= '0';
	 VCC <= '1';
			--		Baud Rate Management Control
  	 OneBit_Time_Reg 	<= 5208;	--50000000Hz/9600 Bps
	 HalfBit_Time_Reg	<= 2604;
		--			Transmission Sequences
recieve:process (clk)
variable bit_ctr		: integer range 0 to 7;
variable Baud_Ctr	    : integer range 0 to 5208;
begin
	if rising_edge(clk) then
		case RX_State is
----------		StandBy Mode, Ready to start Async Transmission
			when Standby	=>
				Wr_En			<= VCC;
				if RX_Pin = GND then
					RX_State		<= Start_Bit_RX;
				end if;
----------		First State receiving Satrt Bit which is 0		-----
			when Start_Bit_RX	=>
				if Baud_Ctr < HalfBit_Time_Reg then
					Baud_Ctr	:=Baud_Ctr+1;
				else
					Baud_Ctr:=0;
					if RX_Pin = GND then	--  the Start bit is gotten correctly
						RX_State			<= Data_RX;
					else
						RX_State		    <= Standby;	--wrong start bit condition it neglects it
					end if;
				end if;
----------		Second State which is sending Data Byte		-----
			when Data_RX	=>
				if Baud_Ctr < OneBit_Time_Reg then
					Baud_Ctr	:= Baud_Ctr+1;
				else
					RX_Reg(bit_ctr) <= RX_Pin;
					Baud_Ctr:=0;
					if bit_ctr<7 then
						bit_ctr:=bit_ctr+1;
					else
						bit_ctr:=0;
						RX_State <= Stop_Bit_RX;
					end if;
				end if;
------------------		End of Sending The Byte				--------
----------		Receiving The stop bit 	(it is not check the stop bit[s])
			when Stop_Bit_RX	=>
					  elsif RX_Pin = GND then
					  else
							Baud_Ctr		:=0;
							Wr_En			<= GND;
							TX_Reg		<= RX_Reg;
				end if;
			when others =>
				null;
		end case;
	end if;
end process;
transmit:process (clk)
begin
		Wr_En_D1 <= Wr_En;						 --Detection of Low egde of Wr_En signal
		if Wr_En='0' and  Wr_En_D1='1' then
			NewData <= '1';
		end if;
		case TX_State is
			when Standby	=>
				TX_Pin	<= VCC;
				if NewData = '1' then
					NewData <= '0';
					TX_State <= Start_Bit_TX;	-- starts sending data
				end if;
----------		First State Sending Satrt Bit which is 0		-----
			when Start_Bit_TX	=>
					TX_Pin	<= GND;
				else
					Baud_Ctr:=0;
					TX_State <= Data_TX;
				end if;
			when Data_TX	=>
					TX_Pin		<= TX_Reg(bit_ctr);
				else
					if bit_ctr < 7 then
						bit_ctr := bit_ctr + 1;
					else
						bit_ctr:=0;
						TX_State <= Stop_Bit_TX;
					end if;
					Baud_Ctr	:=0;
				end if;
----------		 		sending The stop bit 			--------
			when Stop_Bit_TX	=>
					TX_Pin	<= VCC;
				else
					Baud_Ctr	:=0;
					TX_State <= Standby;
				end if;
			when others =>
				null;
		end case;
	end if;
end process;
end simple;
@fpgaamoz
I don't think so there will be any difference. Tool will synthesize the logic in the same manner.
Anusheel
Helpful answer -> Give Kudos
thank you very much.
