Observer hamzaali
why latches are considered bad???
why latches are considered bad in any design and how/why they are created?
Thnx in advance
Hamza Ali
Scholar joelby
Re: why latches are considered bad???
If this is a homework question, consult your class notes or ask your instructor.
Gabor gave an excellent description of why latches should be avoided here (have you tried searching the forum?).
Your HDL textbook should tell you how and why they're created. Here's an excerpt from FPGA Prototyping by Verilog Examples (Chu 2008):
lncomplete branch and incomplete output assignment
The output of a combinational circuit is a function of input only and the circuit should not contain any internal state (i.e., memory). One common error with an always block is the inference of unintended memory in a combinational circuit. The Verilog standard specifies that a variable will keep its previous value if it is not assigned a value in an always block. During synthesis, this infers an internal state (via a closed feedback loop) or a memory element (such as a latch).
Here's a link to the page on Google Books.
Teacher eteam00
Latches are not bad.  They are very very good, in fact.  Most of the very highest performance mainframes and supercomputers of the 1960s, 70s, and 80s were based largely on the use of latches.  I have personally helped design several mainframe computers and array processors with them.  At the risk of over-generalising, their greatest benefit is improved machine cycle time in systems where system clock skew is a significant fraction of the system clock cycle time (period).
Having said that, latches are a very poor match for logic systems implemented in FPGAs.  The performance benefit of latches described above is not realised in FPGA designs because on-chip clock distribution skew is effectively nil.
Latches are considered 'bad' because
  • Latches are almost always unintentionally inferred by poorly written source code
  • FPGA timing tools (and timing based place/route algorithms) are single-mindedly oriented to register-based design
-- Bob Elkind
SIGNATURE:
Summary:
Teacher rcingham
"Latches are almost always unintentionally inferred by poorly written source code"
... or use of a MicroBlaze processor core.
"If it don't work in simulation, it won't work on the board."
Teacher eteam00
Latches in MicroBlaze ????
Latches are used in the MicroBlaze core?  That's interesting!  I've not yet used MicroBlaze, and I would never have guessed right on this point.
Are latches used profusely, or just in one area or application, or is it an optional selection?
-- Bob Elkind
SIGNATURE:
Summary:
Scholar joelby
Re: Latches in MicroBlaze ????
I haven't used it outside of the evaluation period, but UG081 says:
"By using the parameter C_INTERRUPT_IS_EDGE, the external interrupt can either be set to level-sensitive or edge-sensitive:" (p. 68)
Maybe there are a few other places they're used, too. An old post by rcingham on comp.arch.fpga mentions that there are three latches in one particular 10.1 era MicroBlaze core.
On a similar topic, another exciting one to look out for is the gated clock warnings when using ChipScope Pro!
Teacher eteam00
What you describe does not necessarily infer a latch.
-- Bob Elkind
SIGNATURE:
Summary:
This is on purpose in order to detect edge transitions for the DATA bus, TRIGGER bus, or for the inputs of a VIO core where the logic net is used as a clock input to registers.  The timing on these path is not relevant.
Newbie shatakshi16
1. Latches do not have clocks, so, they cannot be synchronized
2. Glitches on the enable pin can give unexpected output
