trustfarm
After PNR, TNS has very big failure , and Running FPGA, it stops.
Hello, previous posting on synthesis.
https://forums.xilinx.com/t5/Timing-Analysis/What-s-difference-on-synthesis-logic-when-TNS-WNS-problem-solve/td-p/964023
After PNR, bitstream generated, but, RUN then FPGA shutdown/reset.
Also, there's Design timing issues. here's snapshot of fault.
It is run on 350Mhz core clock.
How can I resolve it , with incremental way? (for save a pnr time).
Founder https://trustcoinmining.com
I'm a Donde Voy with Poolish.
trustfarm
Also , Power Consume estimation is high, more higher value is TEMP.
Never over 90C.
trustfarm
Is it help? on UG949 page 240~ . block retiming strategy?
or is there carry optimization options , when Implentation?
thanks,
tedbooth
I recommend that you check out the Xilinx "UltraFast Design Methodology":
https://www.xilinx.com/products/design-tools/ultrafast.html#productAdvantages
Lots of good information on proper design techniques and timing analysis.  When designing for clock rates in the 350 MHz range, it is very important to follow all of the recommendations in order to meet timing.  Proper design will also improve the power consumption.
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
drjohnsmith
You need to re look at your code and code for speed... as tedbooth says, design guides.
trustfarm
ok thanks for advices.
we already did  500Mhz , 96% LUT fit, with PCI-e.
Now, we are doing another algorithm, so, there's multiple view of digging.
one of paths rewrite code,
one of paths case by case treat to run, I need to handle xilinx tool option and handy treatment for Ultrafast workaround.
Is there any option for trial?
thanks, in advance.
hemangd
Hi @trustfarm ,
Provide full timing summary report by running report_timing_summary after implementation to evaluate.
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
trustfarm
thanks for interesting.
Here's full reports.
