zvigol
Analyzing Intermediate Timing Summary
Hello
Is there a way to identify and analyze problematic timing paths during routing phase ?
I get message like : Intermediate Timing Summary | WNS=0.238 | TNS=0.000 | WHS=-0.279 | THS=-19.724|
But what are the problematic paths ?
Zvi Goldenberg
zvigol
That's my usual methodology . I was wondering if I can accelerate design analysis and understanding
Zvi
hongh
It's recommended to the analyze the timing result of the final routed dcp. To avoid the hold violation, please try to check the result of report_clock_interaction first.
zvigol
Hello
I do these recommended actions regularly .
However , I am wondering if I can predict the problematic paths meanwhile during routing phase.
Maybe tool is working hard for non-real path ?
Zvi
dpaul24
@zvigol ,
Let the tool do it, believe me, it is very good at it!
What you can ensure at your end before synthesis is a correctly and properly written HDL and fully constrained design. Given these two criterion and assuming that the FPGA has about 20% free space, the tool will come up with best routing.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
zvigol
Zvi
