09-23-2019 06:45 AM
I would like to assign a constraint to an entity.
However, when you search for the Start Point, or End Points the entity name does not appear by itself. Only signals associated with that entity.
How do you get the entire entity?
For example currently I have the following:
set_false_path -from [get_pins UClkGen/Clk120MRstXI_reg/C] .
Don't want this. Want to have:
set_false_path -from [get_pins UClkGen/Clk120MRstXI_reg/C] -to ENTITY_NAME
What is the syntax for the ENTITY_NAME?
09-23-2019 06:57 AM
What do you mean by ENTITY_NAME?
An entity in VHDL is the definition of some digital structure - the definition of some functionality.
The entity doesn't actually exist in your design - only instances of that entity do; you can instantiate one or more instances of that entity.
Assuming you mean a specific instance of that entity, what are you really trying to do?
A static timing path starts at a static timing starpoint; a clock pin of a clocked primitive cell, the cell itself, an input port or a clock; yours is the clock pin of a (presumably clocked primitive) cell. A static timing path ends at a static timing endpoint; a data pin of a clocked primitive cell, the cell itself, an output port or a clock; - an instance of an entity is none of these. In Vivado, you can only constrain static timing paths.
So are you trying to constrain all paths that start at this start point and "end at any valid endpoint within the hierarchy of this instance of the cell"?
If so, the command would be something like
set_false_path -from [get_pins UClkGen/Clk120MRstXI_reg/C] -to [get_cells -hier -filter {(NAME =~ <full_hierarchical_path_name_to_instance>/*) && IS_PRIMITIVE && IS_SEQUENTIAL}]
(Of course, I should probably ask the follow on question - are you sure these paths are false? Reset paths are rarely false...)
Avrum
09-23-2019 06:52 AM
Hi @swimteam ,
If your requirement is to apply set_false_path on entity, i guess you need to use get_cells instead of get_pins.
Raj
09-23-2019 06:57 AM
Avrum
09-23-2019 07:05 AM - edited 09-23-2019 07:06 AM
The constraints were already in Altera which had a false path for the entity. I'm porting to Xilinx.
I found that using cells the entity name showed up. So, now I have:
set_false_path -from [get_pins UClkGen/Clk120MRstXI_reg/C] -to [get_cells UDigitalTuner0/*]
I had to add the "/*" since the no valid endpoint error poped up. But now Vivado accepts the above syntax.
Should I use your syntax instead?
09-23-2019 07:13 AM - edited 09-23-2019 07:13 AM
Yes, there are several potential problems with your syntax:
Avrum
09-23-2019 08:31 AM
How do you find the "full hierarchicial path?"
09-23-2019 08:36 AM - edited 09-23-2019 08:37 AM
09-23-2019 08:44 AM
You're right. The command is now:
set_false_path -from [get_pins UClkGen/Clk120MRstXI_reg/C] -to [get_cells -hier -filter {(NAME =~ UDigitalTuner0/*) && IS_PRIMITIVE && IS_SEQUENTIAL}]
This works.
So you only want the "instance name" and not the entity name. This syntax will then make the reset a false path to not only th Digital Tuner but also any instances that are in it. Is that right?
09-23-2019 08:59 AM
Yes.
But I repeat my earlier statement - Reset paths are rarely able to be treated as false paths. If you declare reset as a false path without the necessary mechanisms to ensure that it really is then your design will fail to reliably come out of reset.
Regardless of whether you are using synchronous set/reset pins of your flip-flops or "asynchronous" preset/clear pins of your flip-flop, the reset signal to those pins must be synchronous - for the preset/clear only the deasserting edge must be synchronous, but it must be synchronous.
The only way a reset can be declared as a false path is if you ensure that the design is completely stable around the deasserting edge of reset - this either means gating your clock around the deasserting edge of reset, or having some other synchronous condition that holds the design in a "reset-like" condition around the deasserting edge of reset.
To be very clear - just because you are using "asynchronous preset/clear" on your flip-flops is not a sufficient reason to declare the reset as a false path.
Avrum
09-23-2019 09:01 AM
Thanks Avrum. I will bring this up at the next meeting.
Swimteam
