12-26-2013 02:50 AM
When I set "offset out" contraint => Too much delay difference from registers to output pads?
NET "InClk" TNM_NET = "InClk"; TIMESPEC TS_InClk = PERIOD "InClk" 12.5 ns HIGH 50 %;
TIMEGRP "OutData"= PADS("o_Data[0]" "o_Data[1]" "o_Data[2]"); TIMEGRP "OutData" OFFSET = OUT 12 ns AFTER "InClk" REFERENCE_PIN "OutClk" RISING;
Extra Information:
I have a source synchronous FPGA data and clock output that I want a fixed relationship
I send the clock using ODDR2, I register the data just before pad.
I want to have a fixed delay :
from several synchronous data registers ------------------------> to the pad (FPGA data outputs)
When I do this I see to much delay difference from the registers (just before the pads) to output pads in trace report.
Clock Structure:
InClk ----> PLL ----> clk_80mhz -------> OutClk through ODDR2
-------> Registers (Internal register just before pad)
12-26-2013 03:49 AM
I am using Spartan 6 100 and PlanAhead 14,6
12-26-2013 05:32 PM
Did you place the data registers into IOB? That will ensure a more fixed delay than the slice registers.
