u24c02
Basic Question for Timing Violation at Timing Analysis
Hi Sir,
What if there are Timing Violation Issue, How to fix the problem at Timing Analysis at Four categories of timing paths ?
1. Register to Register (reg2 reg)
2. Register to Output (reg2 out)
3. Input to Register (in2 reg)
4. Input to Output (in2 out)
yashp
Answer to your question is not simple. There is no straight forward or thumb rule to get it fixed all the time.
STA is a vast topic and the similar looking violations for two different path can be due to different root cause.
I would suggest you to read the documents UG903 and UG906 to understand the basics of STA.
I hope this information will be helpful.
Yash
yashp
Yash
