kendrick
Basic Timing Constraints Question
We are trying to use a Kintex-7 to drive a 1GSPS DAC. The data is presented to the DAC on a 500MHz DDR 16-bit bus with the 500MHz clock strobing in the data on the rising and falling edges.
In order to generate the 500MHz clock, we use a clock wizard to multiply an external 250MHz source by two. We have named this 500MHz clock net "dacClkGen" in the VHDL code. The PAD for the external 250MHz clock is "CLK_EXT_P." The pads for the 16 bit data lines are "DAC_DP*", and the output 500MHz clock pad to the dac is "DAC_DCLKP." DAC_DCLKP is connected directly to "dacClkGen."
If we are reading the datasheets correctly, the output clock's rising edge must be 300ps before the positive edge data is valid, and the falling edge must be 350 ps after the falling edge data is valid.
We have the following constraints in our .ucf file:
NET "Inst_DAC_Data_Generator\dacClkGen" TNM_NET = "dacClkGen";
NET "DAC_DP*" OFFSET = OUT 350ps AFTER "CLK_EXT_P" RISING;
NET "DAC_DP*" OFFSET = OUT 300ps BEFORE "CLK_EXT_P" FALLING;
The problem is that during the map phase, I am given a warning stating that the net "dacClkGen" has been optimized away, so my constraint is ignored. Is there a way to force the dacClkGen net to remain so that these constraints won't be ignored? Or is there a better way to enter these constraints?
austin
k,
I think you would be better off to use a clock forwarding style output (DDR output flop) for your clock, so it is precisely aligned with the data, and then align the clock by using pcb traces to adjust for the 300 to 350ps delays.  This will guarantee timing over all process, voltage and temperature in a way that will be difficult, if not impossible to accomplish in the FPGA device.
If you must do the delay in the FPGA device, look at using the phase shift features of the MMCM.  Using place and route to provide 300 ps of delay is not going to be very satisfactory (in my opinion).
Austin Lesea
Principal Engineer
Xilinx San Jose
gszakacs
Professor
Professor
There is no way at all to enter the constraints you want.  Basically, source synchronous logic must work
by design - not by constraint.  But if you want a small synopsis of your constraint failure, it starts with
using an output net in a TNM_NET constraint.  TNM_NET looks forward from the named net to any
clocked loads (FFs, BRAMs, DSPs, etc.) and creates a group from those instances.  Going forward
from an output net there is nothing inside the FPGA to create this group from, so the constraints that
use the group are ignored.
OFFSET OUT constraints are always relative to an input clock at the FPGA pad.  The only reasonable
OFFSET OUT constraint uses the AFTER keyword, OFFSET OUT BEFORE makes no sense.  This
constraint is to allow you to put a cap on prop delay through the FPGA from clock in to data out.
What you really wanted was some sort of output skew constraint, and that doesn't exist.
There is a Timing Constraints blog in the forum blogs section.
-- Gabor
-- Gabor
