pinguin_agya
Bi-directional IOs with DDR - timing issue or design problem?
i want to design a SPI-Slave with bi-directional data ports (SIO) and DDR on an Artix7 (xc7a35t). Can you give me a design advise for the SIOs.
Ports:
SCLK : in std_logic;
nCS : in std_logic;
SIO : inout std_logic_vector(7 downto 0);
My suggestion was using IOBUF + ODDR for this IOs. The IOBUF will be automatically created by Vivado using the following assignment:
SIO <= SO when SO_en = '1' else (others => 'Z');
SCLK-Frequency is about 40 MHz. The IO-Timing Constraints are given by a uController. According to the data sheet, i have to set the following IO-Constraints (@40MHz, in ns).
# input timing for FPGA (SPI Slave)
set i_setup_rise 8.5
set i_setup_fall 5.5
set i_hold_rise 3.5
set i_hold_fall 3.5
# output timing for FPGA (SPI Slave)
set o_setup_rise 1.0
set o_setup_fall 1.0
set o_hold_rise 6.0
set o_hold_fall 5.5
Timing constraints:
# 40 MHz serial clock
create_clock -period 25 -name sclk -waveform {0.000 12.5} -add [get_ports SCLK]
# input - rising clock edge
set_input_delay -clock sclk -max 8.5 [get_ports SIO]
set_input_delay -clock sclk -min 3.5 [get_ports SIO] -add_delay
# input - falling clock edge
set_input_delay -clock sclk -clock_fall -max 5.5 [get_ports SIO] -add_delay
set_input_delay -clock sclk -clock_fall -min 3.5 [get_ports SIO] -add_delay
# output - rising clock edge
set_output_delay -clock sclk -reference_pin [get_ports SCLK] -max 1 [get_ports SIO]
set_output_delay -clock sclk -reference_pin [get_ports SCLK] -min -6 [get_ports SIO]
# output - falling clock edge
set_output_delay -clock sclk -clock_fall -reference_pin [get_ports SCLK] -max 1 [get_ports SIO] -add_delay
set_output_delay -clock sclk -clock_fall -reference_pin [get_ports SCLK] -min -5.5 [get_ports SIO] -add_delay
The Timing requirements are not met. The input timing has no error, but the output timing has setup and hold violation (see timing calcuation below).
Can you give me some advice for the design or timing constraints(mabye IOBUF + ODDR is not the best solution)?
Kind Regards,
Pinguin
# SETUP PATH
| Tool Version : Vivado v.2017.3.1 (lin64) Build 2035080 Fri Oct 20 14:20:00 MDT 2017
| Date : Wed Nov 21 09:16:29 2018
| Command : report_timing -to [get_ports {SIO[0]}]
| Design : SIO_DDR_SPI_example
| Device : 7a35t-ftg256
| Speed File : -1 PRODUCTION 1.19 2017-08-11
Timing Report
Slack (VIOLATED) : -4.308ns (required time - arrival time)
Source: SO_en_reg/C
(falling edge-triggered cell FDCE clocked by sclk {rise@0.000ns fall@12.500ns period=25.000ns})
Destination: SIO[0]
(output port clocked by sclk {rise@0.000ns fall@12.500ns period=25.000ns})
Path Group: sclk
Path Type: Max at Slow Process Corner
Requirement: 12.500ns (sclk rise@25.000ns - sclk fall@12.500ns)
Data Path Delay: 10.553ns (logic 4.002ns (37.922%) route 6.551ns (62.078%))
Logic Levels: 1 (OBUFT=1)
Output Delay: 1.000ns
Clock Path Skew: -5.220ns (DCD - SCD + CPR)
Destination Clock Delay (DCD): 0.000ns = ( 25.000 - 25.000 )
Source Clock Delay (SCD): 5.220ns = ( 17.720 - 12.500 )
Clock Pessimism Removal (CPR): 0.000ns
Clock Uncertainty: 0.035ns ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
Total System Jitter (TSJ): 0.071ns
Total Input Jitter (TIJ): 0.000ns
Discrete Jitter (DJ): 0.000ns
Phase Error (PE): 0.000ns
Location Delay type Incr(ns) Path(ns) Netlist Resource(s)
(clock sclk fall edge) 12.500 12.500 f
C11 0.000 12.500 f SCLK (IN)
net (fo=0) 0.000 12.500 SCLK
C11 IBUF (Prop_ibuf_I_O) 1.527 14.027 f SCLK_IBUF_inst/O
net (fo=1, routed) 1.972 15.999 SCLK_IBUF
BUFGCTRL_X0Y16 BUFG (Prop_bufg_I_O) 0.096 16.095 f SCLK_IBUF_BUFG_inst/O
net (fo=30, routed) 1.625 17.720 SCLK_IBUF_BUFG
SLICE_X1Y52 FDCE r SO_en_reg/C (IS_INVERTED)
SLICE_X1Y52 FDCE (Prop_fdce_C_Q) 0.459 18.179 f SO_en_reg/Q
net (fo=4, routed) 6.551 24.730 genSerialOut[0].IOBUF_SCLK/T
G11 OBUFT (TriStatE_obuft_T_O)
3.543 28.273 r genSerialOut[0].IOBUF_SCLK/OBUFT/O
net (fo=1, unset) 0.000 28.273 SIO[0]
G11 r SIO[0] (INOUT)
(clock sclk rise edge) 25.000 25.000 r
C11 0.000 25.000 r SCLK (IN)
clock pessimism 0.000 25.000
clock uncertainty -0.035 24.965
output delay -1.000 23.965
required time 23.965
arrival time -28.273
slack -4.308
# HOLD Path
| Date : Wed Nov 21 09:17:44 2018
| Command : report_timing -to [get_ports {SIO[0]}] -hold
Timing Report
Slack (VIOLATED) : -3.089ns (arrival time - required time)
Source: genSerialOut[0].ODDR_1/C
(rising edge-triggered cell ODDR clocked by sclk {rise@0.000ns fall@12.500ns period=25.000ns})
Destination: SIO[0]
Path Group: sclk
Path Type: Min at Fast Process Corner
Requirement: 0.000ns (sclk rise@0.000ns - sclk rise@0.000ns)
Data Path Delay: 1.407ns (logic 1.406ns (99.929%) route 0.001ns (0.071%))
Output Delay: -6.000ns
Clock Path Skew: -1.540ns (DCD - SCD - CPR)
Source Clock Delay (SCD): 1.540ns
Clock Pessimism Removal (CPR): -0.000ns
(clock sclk rise edge) 0.000 0.000 r
C11 0.000 0.000 r SCLK (IN)
net (fo=0) 0.000 0.000 SCLK
C11 IBUF (Prop_ibuf_I_O) 0.295 0.295 r SCLK_IBUF_inst/O
net (fo=1, routed) 0.634 0.929 SCLK_IBUF
BUFGCTRL_X0Y16 BUFG (Prop_bufg_I_O) 0.026 0.955 r SCLK_IBUF_BUFG_inst/O
net (fo=30, routed) 0.585 1.540 SCLK_IBUF_BUFG
OLOGIC_X0Y50 ODDR r genSerialOut[0].ODDR_1/C
OLOGIC_X0Y50 ODDR (Prop_oddr_C_Q) 0.177 1.717 r genSerialOut[0].ODDR_1/Q
net (fo=1, routed) 0.001 1.718 genSerialOut[0].IOBUF_SCLK/I
G11 OBUFT (Prop_obuft_I_O) 1.229 2.946 r genSerialOut[0].IOBUF_SCLK/OBUFT/O
net (fo=1, unset) 0.000 2.946 SIO[0]
clock pessimism 0.000 0.000
clock uncertainty 0.035 0.035
output delay 6.000 6.035
required time -6.035
arrival time 2.946
slack -3.089
takayos
Hi Pinguin,
I have 2 suggestions.
  • Review set_output_delay constraint.
you said “the timing is related to SCLK Pin”, is this really true?
I think “Timing diagram from uC” is drowned from master point of view,  which means related “clock” is at their port.
From their port to FPGA, there should be trace delay.
We can possibly ignore it for inputs side, because both data and clock has almost same value(compensated). But not for output side.
For instance, if clock takes 3 ns to arrive at FPGA.
Setup should be 1 + 3 = 4ns and hold should be 6 – 3 = 3ns.
  • Review SO_en FF
I can see FDCE as SO_en, means it is not in IO block. That is why Data Path Delay is big(10.553ns).
It appears it drives 4 OBUFT, so tool cannot place it into IOB(should be single connection)
Can you please make it 4 ( for each port) and make sure it is in IOB.
Hope this help.
Takayos
Don`t forget to reply, kudo, and accept as solution
dsheils
Could you please show a timing diagram of the required setup/hold times and how the data and clock are aligned? Thanks.
David
pinguin_agya
Hello David,
thanks for your response!
I hope the timing diagram and block diagram gives you a good overview about the timing.
Block diagram:
Timing diagram from uC (values - see block diagram):
Typical SPI transmission:
Blue SIO data: Request from Master (used for Input delay arrows)
Yellow SIO data: response to Master (from Slave - used for Output delay arrows)
Z:= High impedance (switch direction of SIO)
Data driven with falling clock edge, will first be latched with rising edge at receiver (and vice versa).
According to the Xilinx Templates I used for input delays the template Source synchronous DDR example and for output delays the source synchronous DDR Example (see below). The clock is defined with 40Mhz.
# Edge-Aligned Double Data Rate Source Synchronous Inputs
# (Using a direct FF connection)
# input             _________________________________
# clock   _________|                                 |___________________________
#          skew_bre|skew_are                 skew_bfe|skew_afe
#        _         |       _________________         |       _________________
# data   _XXXXXXXXXXXXXXXXX____Rise_Data____XXXXXXXXXXXXXXXXX____Fall_Data____XX
# Double Data Rate Source Synchronous Outputs
# forwarded                      ________________________________
# clock               __________|                                |______________
#                         tsu_r | thd_r                    tsu_f | thd_f
#                       ________|_________               ________|_______
# data @ destination XXX__________________XXXXXXXXXXXXXXX________________XXXXX
Note: For output timing i've used the -reference_pin because the timing is related to SCLK Pin.
Kind Regards,
Martin
avrumw
Guide
Guide
It looks like you have a couple of problems...
First, it's very hard to read the timing report you posted - the format is all messed up. Maybe you can repost it with better formatting - either a screen shot of the graphic report, or a pure (formatted) text report - you may need to put it in an "Insert Code" box to preserve the formatting (with the new Forum format I don't know exactly what the interface does with formatted reports).
But the big problem is your output hold time. The device needs 6ns of output hold time, but you have not described an architecture that has the ability to generate this. The 6ns requirement is from the SCLK input - you have it going through a BUFG and directly to an ODDR flip-flop and OBUF (for the "data output" part of your output). With this architecture, the only hold time you get is the "natural" hold time from the propagation of these components, which is not enough to satisfy the 6ns requirement. So you get a hold time failure from the ODDR.
However, for the tristate enable part of your output, the tristate enable control is not packed in the IOB - it is using a fabric flip-flop. It probably shouldn't - you should get it packed into the IOB - you may need to set the IOB property on the output or even directly on the tristate flip-flop (you may have to play with it a bit to get this done). With it in the IOB flip-flop, whatever solution you do to get the output data path to pass will also work for the tristate path. But, as it is, since the tristate FF is in the fabric, the tool can add additional routing delay to get it to meet the 6ns hold time requirement. In doing so, it is adding TONS of additional routing to this path (and may even get this path to meet the required hold time). But because of all this additional routing, the path is now violating the setup requirement.
The solution is to come up with an architecture that allows you to meet this hold time requirement. If the I/O is a High Performance (HP) I/O then you can consider using the ODELAY to give you the delay you need. The advantage of the ODELAY (over routing) is that it is Process/Voltage/Temperature compensated - with routing delay, for every 1ns the tool adds at "FAST" process, this results in around 3ns at "SLOW" process - with the ODELAY the value is almost identical at both process corners.
If this is not an option, then things become more complicated. Is your SCLK always running, or is it gapped? If it is always running then you can use an MMCM. With the MMCM, you can specify a phase delay between the input clock and the output clock. By adding an MMCM delay to the clock, you can push the clocking of the IOB flip-flops (and DDR flip-flops) forward to satisfy the hold time requirement of the external device. However, if the SCLK is gapped (not running when there are no accesses  on the serial bus) then you cannot use an MMCM.
If neither of these cases are available (the SCLK is gapped and the IO is in a High Range I/O), you may be in trouble - even though this interface is slow-ish (40MHz DDR), it is probably too fast to oversample, and has timing requirements that you cannot meet with the resources you have available.
Finally, a quick note. The -reference_pin option is not useful here - you have already specified the timing with respect to the clock you defined on the SCLK pin, so the tool understands that relationship. The "reference_pin" option is used only when you want to relate one output to a clock that is also an output of the FPGA. Even then, this only gives you a report, which was all the old tool - ISE - could do. With Vivado, even in this case, you can properly define the timing relationship of this system with a generated clock - so the -reference_pin is basically a useless option (it's merely to give ISE users an option to get the kind of analysis they used to have).
Avrum
pinguin_agya
Hello avrumw,
thanks for your detailed answer!
Using the IOB attribute for the tristate input of the IOBUFT works and improves the setup timing! Using the IOB-attribute on the tristate-buffer the timing problems are reduced to some hold Pathes (from SIO and to SIO). So, I add some IDELAYs into the input pathes and fix the hold times "from SIO".
Now, i got only hold violations on the output data path (to SIO). This pathes has a worst hold slack of -3ns (Path from ODDR/C to SIO[*] ).
In Artix7 there are NO ODELAY primitives available (only HR IOs)! Can I use other primitives to apply some additional delay on the clock-path of the SIO output? (OSERDES, BUFG/BUFR, ...)
Do you have any ideas?
Kind regards
Pinguin
sandrao
Community Manager
Community Manager
Hi @pinguin_agya,
Could you post the latest timing report? Would be useful to see the slack on the other paths that would be impacted by adding delay on the clock path.
You could use the IDELAY on the SCLK input but you'd need enough slack on the input path.
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
pinguin_agya
after adding the IDELAY on SCLK the HOLD slack of the SO_enable path is compensated. But the same path (SO_enable) got a negative slack on the setup path for the SIOs with the IDelay.
According to the timing reports there are no other pathes with timing violations.
timing summarytiming summary setup pathessetup pathes
@sandrao: see the attached timing report (text file).
Best Regards,
Pinguin
dsheils
Can you confirm if your SCLK is running continously or if there are gaps in the clock during transfer? If it's continuous can you try the MMCM approach as described by Avrum above?
Best Regards,
D
pinguin_agya
the interface clock - SCLK - is gapped. So, i cannot try the MMCM approach.
Can I delay the gapped input clock with an IDelay?
Best Regards,
Pinguin
takayos
Hi Pinguin,
  • Review SO_en FF
Hope this help.
Takayos
pinguin_agya
thanks for the reply!
Suggestion 1: Review set_output_delay constraint
You are right, for the output delay i can reduce the hold time/increase setup time because of the trace delay. This will reduce the hold time. But I think a board delay of 3ns is a bit too much for my design. I will talk to my hardware designer to get the correct value. I will inform you about the newes
Suggestion 2: SO_en_ff
This issue is solved with the set_property IOB constraint for the Ports. See the latest timing reports above (2 or 3 replys earlier).
Best Regards,
Pinguin
