CDC 2 Flip Flop synchronizer for Zynq
I am trying to solve a CDC error by using a 2 Flip Flop synchronizer technique as shown below. But Vivado is not recognizing it as a CDC circuit and flagging an error for the first Flip Flop which is signal1.
attribute ASYNC_REG                    : string;
attribute ASYNC_REG of signal1: signal is "TRUE";
attribute ASYNC_REG of signal2: signal is "TRUE";
                CDC_sync: process(clk) begin
                                if rising_edge(clk) then
                                               signal1 <= in_signal;
                                                signal2 <= signal1;
                                end if;
                end process;
Thanks in advance.
Re: CDC 2 Flip Flop synchronizer for Zynq
What error did you receive about signal1?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Thanks for the response. I get the following warning when I run report clock interaction
NameSlackLevelsHigh FanoutFromToTotal DelayLogic DelayNet DelayLogic %Net %RequirementSource ClockDestination ClockExceptionSkew
Constrained Paths (1)
clk_1x_PLL_CLK_DDR_In (10)
Path 1-8.6744design_1_i/TopLevel_1/U0/U55/in_signal_reg/Cdesign_1_i/TopLevel_1/U0/U7/U1/signal1_reg/D3.721.152.5830.7769.230.00clk_50Mhz_PLL_40Mhzclk_1x_PLL_CLK_DDR_In -4.62
In Vivado,
All data crossings are assummed synchronous by default, so you must exclude the clock domain crossing path with a constraint.  Then your timing error will go away.
l.e.o.
As indicated by lowearthorbit, all clocks are related by default. Using sync flops with "ASYNC_REG" property would tell the tool to place the two flops in the same CLB. You still need to add a false path constraint to the signal1 flop.
Peter Kwan, Senior FPGA Engineer
Designlinx Hardware Solution, Inc
Guide
Guide
Careful - "You still need to add an exception to the path ending at the signal1 flop". The correct exception isn't always a "set_false_path" - depending on the characteristics of the clock domain crossing circuit, it may need to be a "set_max_delay -datapath_only"...
Avrum
Can I use XPM_CDC_SINGLE so that Vivado can recognize it as a synchronizer solution for CDC and will not flag critical warning for signal1.
Accoring to AR# 67738, it will add false path to the receiving flop. You still need to becareful as per @avrumw  comment.
