Clock domain tutorial
could someone point me to documentation about multiple clock domain design ? I'm discovering the concept !
I'm a beginner, I did some things with a spartan3, basic examples in vhdl, but always with a single clock at 50MHz on the board.
I read that the ram and the multipliers on that fpga could run above 250MHz.
How can I create a module (using ram and mult) running at 100MHz with other modules running at 50MHz ?
Any simple VHDL code ?
Thank you
Hi @raiatea
Check this document:
https://www.ece.ucsb.edu/its/bluespec/training/BSV/slides/Lec10_Multiple_Clocks.pdf
Rohit
Rohit
Thank you for the link. Multiple clocks looks widely used in SoCs, but I can't find clear examples.
I looked too at the Timing Closure User Guide ug612, p157
I'm thinking about the following :
 - use the board clock at 50MHz and a PLL to generate clk0 at 50MHz, and clk2x at 100MHz
 - use clk0 for the modules at 50MHz and clk2x for the module at 100MHz
 - use a synchronous FIFO for crossing the domains
Any link to a code example in ISE, Vivado, university program, workshop,
or a book chapter about multiple clock design on FPGA ?
or you could run everything at 100 mhz, and a clock enable for the slower part of the circuit.
