ezern
Configure Stepping with xdc files in Vivado
Hi everybody,
I am using VIVADO for my Virtex/Kintex 7 devices and I do want to specify the stepping.
With ucf files it was easy to do this because of the tutorial on http://www.xilinx.com/support/answers/20947.htm.
For ucf files the command is: CONFIG STEPPING="n";
(n is the stepping e.g. ES for engineering sample)
For xdc files i have tried:
set_property STEPPING ES
or
set_property STEPPING "ES"
But neither of these is working. That is why I am returning the question you.
Thanks in advance for the answers.
mcgett
What do you mean that is not working?  And what device (die, package, speed grade) are you using in the tools?
ezern
Well, when I implement I get the error message:
[Common 17-163] Missing value for option 'objects', please type 'set_property -help' for usage info. ["D:/KC705/MeineFirmware/GTX_VIVADO_START/Test17.2/Test17.2.srcs/constrs_1/imports/Master UCF/KC705_Rev1_0_U1_ucf.xdc":1]
So I do not think Vivado takes the stepping as engineering sample. Is there a way to do it in Vivado?
