Confused on timing constraints
Hi everyone,
I have a design with a component that creates packets, and a FIFO (at a different hierarchy level) that accepts the data. I assert the FIFO's wr_en from the packet formatting instance and I want to constraint its datapath. Both instances are clocked by the same clock.
I tried adding this line at the .xdc:
set_max_delay -from [get_pins {packet_formation_instance/daqFIFO_wr_en_reg/Q}] datapath_only -2
But I get this warning:
[Common 17-165] Too many positional options when parsing '2', please type 'set_max_delay -help' for usage info. ["/home/Documents/done/constrs_1/constraints.xdc":1]
I have a feeling that I am doing something very wrong. If both instances are clocked by the same clock do I have to use set_max_delay? Is there a better solution for this? Another command?
Thanks!
this should be "-datapath_only 2" for the command to work properly.
But for the case "Both instances are clocked by the same clock" you don't need this at all. The timing engine is capable of timing this path.
For the single clock case, you just have to create a clock (create_clock) pointing to the source of the clock and its period. That will tell the timing engine how to process all relevant paths.
muzaffer,
Thank you for your fast and precise reply. It really helped. As you have understood, I don't have serious .xdc/constraining experience and I am currently reading ug903 for more info.
Can I ask another more general question? Suppose that I have two different instances that are in different hierarchy levels (like my original post, the packet formation instance and the FIFO). Would it be a good choice to create a custom IP out of these two? Does a custom IP have more "strict" constraints in its internal circuitry? Does vivado implement it as a block and therefore packs its registers/LUTs/rams closer together? Because if it does, wouldn't that be a good alternative over constraining every single datapath between the previously separated blocks?
Thanks again
@cbakal
Even if you create the custom IP, you should specify the IP constraints. Refer http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1118-vivado-creating-packaging-custom-ip.pdf for more details.
Sravanthi
If you plan to use it again in the future probably so.
Not really or not that I am aware of.
No. At least not because they are in the same custom IP. Vivado considers connectivity for packing & other placement. So even if they are not in the same custom IP, they would be packed together if connectivity suggests so.
Again, for a synchronous single clock system with edge based registers, there is no reason to constrain "every single datapath". You need to create one clock constraint which the timing engine enforces on every path created by this clock.
