Visitor staslapanja
Constraining LVDS inverted clock
In our project we are using a LVDS clock source to capture data from an ADC device (DDR). The clocking is done in this way:
INPUT (P,N) -> MMCM -> BUFG and BUGCE_DIV (in parallel) -> capture logic (IDELAY and ISERDES3)
However on our board the P and N LVDS pins were swapped effectively inverting the clock. To counter this a 180 degree phase shift was added to the MMCM output clock.
My question is how should a LVDS clock that has switched PN pins be constrained for our scenario. Should the clock be defined like this:
create_clock -period 2.000 -name clock -waveform {1.0 2.0} [get_ports clock_pad_p_i]
Are there any other changes to the constraints that need to be taken into account?
Thank you.
Historian
Historian
Re: Constraining LVDS inverted clock
My guess is that the question/problem is more complex then this.
Yes, the command given by @evant_nq describes a clock that has a falling edge at time 0 and a rising edge at time 1, however, that, on its own, does not describe the edge relationship you want.
For example, if you use
set_input_delay -clock clock 0.5 [get_ports data_pad]
this will still define a 0.5ns delay with respect to the rising edge of the clock, regardless of whether the rising edge is defined to be at 0ns or at 1ns.
If you really want to describe the data transitioning with respect to the falling clock then you need to use the -clock_fall option
set_input_delay -clock clock 0.5 [get_ports data_pad] -clock_fall
this is really what tells the tool that the input changes relative to the falling edge of the clock (not the rising edge).
And given that this is the case, there is no real advantage to defining the clock with the -edges {1 2} rather than the default (which is {0 1}) - the -clock_fall is what does what you need it to do...
If you really want to do it with clocks, then you will need two clocks - a real one and a virtual one
create_clock -period 2.000 -name virt_clock -waveform {0.0 1.0}
set_input_delay -clock virt_clock 0.5 [get_ports data_pad]
Now your data is defined to change on the rising edge of virt_clock (with rising edges at 0 and 2), but the FPGA is getting a clock that is 180 degrees out of phase. In Vivado all clocks are related by default so the tool understands that these two clocks are related and are 180 degrees apart.
Avrum
Hi staslapanja,
  I think the create_clock:
Should give you the expected shift. The best way to confirm this is to run timing with the constraint, and then do a report timing on the input paths.
The clock should start with a 180 degree shift compare to the data (You can do the normal waveform of 0 1 to confirm)
Which means the tools will be trying to cacualting timing of the data assuming the rising edge is 180 out of phase
Historian
Historian
Avrum
Visitor staslapanja
Thank you both for your replays, especially yours avrumw.
