02-27-2021 04:55 PM
Hello, newbie here with how to create a Generated Clock Constraint. Here is my example:
Here is the Generated Clock Window:
What do I enter in the Master Pin (Source) block?
Would that be the I/O Port Clock_IN?
What goes in Master Clock block?
What if my Generated Clock is generated from a state machine, what would I enter in the Derive from Source Clock Waveform?
Thank you
Joe
02-27-2021 08:07 PM
First, it is generally a bad idea to generate a clock with anything other than dedicated clocking resources (the MMCM/PLL and associated clock buffers) - this is not an SDC/XDC thing, but an FPGA architecture thing - take a look at this post on why fabric generated clocks are generally not the best idea.
But from an XDC/SDC point of view it is legal to define a generated clock where the clock is generated by logic (given the caveats mentioned in the post).
In most cases there is an actual cell that is doing the transformation of the clock. This cell can be
When you do a create_generated_clock, it is preferred to specify the Master pin (i.e. the -source option) as close to the generating cell as possible
However, it is acceptable to put any point upstream from that that carries the source clock. In this case, you could use
The object to which it is attached would normally be
But can also be something directly downstream of this
As for the Derive from Source Clock Waveform (the relationship between the source clock and the generated clock), this depends on how the clock is generated. The obvious question is "how are you going to generate 48MHz from 100MHz? There is no simply relationship between these two, how are you going to create this clock.
The only way digital logic can create a clock like this is with some kind of dithering - the ratio is 2.08333x, so you could do something that has one output edge every 2nd or 3rd input edge in the exact right ratio between them to generate the clock you want. But if you do this, it isn't a "true" clock - you cannot describe this as a 48MHz clock. Since there are some periods where the subsequent edges of the clock are 2 100MHz clocks apart, this will have the behavior of a 50MHz (not 48MHz clock) - any downstream logic that uses this will have to be budgeted to allow for the 20ns period between subsequent edges - this would be Divide source clock frequency by 2 (-divide_by 2). If (somehow) you did manage to generate a true 48MHz clock (again, not possible with digital logic), then you could specify Multiply=12 Divide=25 (-multiply_by 12 -divide_by 25) - the tools would accept this.
But, again, this is not recommended. If you are going to do some kind of dithering of the clock, rather than have the clock generated by the output of a flip-flop, you could use a BUFHCE/BUFGCE and control the enable with the appropriate profile - enabled every 2nd or 3rd source clock in the appropriate pattern. Take a look at this post on using a BUFGCE/BUFHCE to generate a clock.
Avrum
02-27-2021 08:07 PM
Avrum
03-01-2021 06:11 AM
03-01-2021 09:38 AM
Hello, I have some additional information that may help you help me with the SDC constraints.
The Generated Clock is 2.5Mhz:
Clock from RTL State Machine
RTL Schematic
The AZ clock is generated by a state machine that I will attach:
Is the the schematic path:
03-01-2021 09:45 AM
The always block that generates this 2.5Mhz clock is from sclk_x4 and it comes from an MMCM
I could try creating the constrain based in the input pin to the MMCM:
The PL_LOCK_REF_CLK input to the MMCM is a differential input, so which leg of the pair should I use?
I also could try the output cell of the MMCM:
Again, the AZ_CLK that I constraining is a 2.5Mhz bursted clock to connect to a device that supports SPI.
I'll keep trying.
Thank you
Joe
03-01-2021 10:45 AM
Hello, I've made some progress:
Here is the Source Object:
Source Object
Now, here is the Master Source
Master Clock
Now here is my first SDC.
My First SDC
I now have to do the same for the other SPI interfaces: EL_L and EL_R.
I have only Synthesized the design and run Timing Summary.
Small steps for me.
Joe
03-01-2021 12:50 PM
Thank you very much helping me with this timing problem. I was able to get rid of the warnings. Now onto the other warnings.
Joe
