Advisor
Advisor
Cross-probing signals in ISE 11.1 Timing Analyzer
Before ISE 11.1 I could use Floorplanner to cross-probe Timing Analyzer signals.
In ISE 11.1 PlanAhead replaced Floorplanner, and there seems to be no way to do cross-probing with PlanAhead.
Cross-probing with FPGA Editor is almost useless because I cannot see floorplanning information.
Is there any workaround for this.
You can import the timing report to PlanAhead and then do the cross-probing in PlanAhead. If you run "Analyze Tiing/Floorplan Design (PlanAhead) from Project Navigator GUI, you don't need to manually import he timing result.
Cheers,
Jim
Cheers,
Jim
