patilvinayak5653
DCM bounds frequency to 150.015MHz
In dff code I have used DCM from Language template.
module dff_async_reset (data,clk,reset,q);
input data, clk, reset ;
output q;
reg q;
DCM_BASE DCM_BASE_inst (
.CLK0(CLK0), // 0 degree DCM CLK output
.CLKFB(CLK1), // DCM clock feedback
.CLKIN(clk), // Clock input (from IBUFG, BUFG or DCM)
.RST(0) // DCM asynchronous reset input
BUFG BUFG_inst (
.O(CLK1), // Clock buffer output
.I(CLK0) // Clock buffer input
always @ ( posedge CLK1 or negedge reset)
if (~reset) begin
q <= 1'b0;
end else begin
q <= data;
end
endmodule
and then I have given constraint  like
NET "clk" TNM_NET = clk;
TIMESPEC TS_clk = PERIOD "clk" 3 ns HIGH 50%;
OFFSET = IN 3 ns VALID 3 ns BEFORE "clk" RISING;
OFFSET = OUT 3 ns AFTER "clk";
But timing constraint fails. I have attached timing constraint report image.
Report is saying that best case achievable for clock period is 6.66ns.
Whenever I am using DCM for any design it says   that best case achievable for clock period is 6.66ns.
Why it is happening ? Is it case that DCM can achieve maximum of 150 mhz?
I am working on vertex5. xilinx 13.2
austin
p,
The DCM in V5 will run up to the max frequency of the global clock resources, 3ns, or 333 MHz is just fine (no problem).
I suspect you just can not run that fast because you have too much logic in your critical paths.
Try pipelining.  When a design does not meet timing, do not blame the DCM!
Austin Lesea
Principal Engineer
Xilinx San Jose
hgleamon1
Your failing path is the input clock to the design, rather than the DCM produced clock.
What other logic is being used by your "clk"?
"That which we must learn to do, we learn by doing." - Aristotle
