DNA_PORT Clock Timing Problem: Spartan 6 ISE 14.7
I coded up the DNA_PORT module to get a unique ID.
The problem is, the DNA_PORT needs a very low clock frequency of 2MHz max.     However, this is too low for the clock generators or PLLs to generate.    I can manually code up flip-flops to divide down the clock.    BUT, that loses the automatic timing checks.   How do I generate this the low DNA_PORT clock frequency while keeping the tool timing checks?
Re: DNA_PORT Clock Timing Problem: Spartan 6 ISE 14.7
You can set period constraint on the output pin of the generated clock, then this clock will be analyzed.
Thank you.
This works partially.   I put in my vhdl code the following:
constant dna_clock_period : integer := CLOCK_PERIOD * 16;
constant dna_clock_period_str: string := integer'image(dna_clock_period);
attribute period: string;
attribute period of dna_clock : signal is dna_clock_period_str & "ns";
So the synthesizer picks this up is seen from the wrapper report:
Set property "PERIOD = 640NS" for signal <dna_clock>.
BUT, this does not get propagated into the main post-par timing report (.twr).   The slow clock is not seen as a derived clock in the .twr file.    BTW, setup failures will never be seen at these slow clock frequencies, but hold failures can happen at any frequency.
Please try to set the period constraint in UCF, instead of VHDL code.
