Voyager
Voyager
Default Time scale in vivado simulator
I would like to know which time scale is in vivado simulator by default? ps or ns or us?
Does setting timescale in source code like `timescale 1ps/1ps have any impact on it?
Guide
Guide
The 'timescale specifies how time is managed in the Verilog simulator. It contains 2 numbers, the time unit and the precision; so 1ns/100ps means that the time unit for the Verilog code that follows has a time unit of 1ns with a resolution of 100ps. So this means that #1 means 1ns, #1.1 mean 1.1ns, but that #1.15 also means 1.1ns (since the resolution is only in increments of 100ps, or 0.1ns).
The resolution is a bit more complicated, because the resolution in a simulation is the value of the smallest resolution specified in any code. So if you have a 1ns/100ps in one part of the code and 1ns/1ps in another part of the code, the code is all effectively 1ns/1ps.
The 'timescale is a compiler directive, so it pertains to the code that is parsed after this code - it is not related to modules or even necessarily to files. It is therefore customary to either:
  • Put a 'timescale at the top of every file
  • Don't use it at all (in which case the simulator will use the default, which I think is 1ps/1ps
  • Put it only in the top of your testbench and ensure that it is the first file read
If you do not have a 'timescale in the first file/files read, but you do in a later file, you will get a warning message...
Avrum
Simulator is in ps,
in verilog, as far as I remember, the `timescale 1ps/1ps  only affects things like #10 assignment,
   where if you put `timescale 1ps/1ps  and have #10, thats 10 ps,
    where as if you put `timescale 100ps/100ps  and have #10, thats 1000 ps ( 1 ns )
Guide
Guide
Avrum
Voyager
Voyager
@avrumw
Don't use it at all (in which case the simulator will use the default, which I think is 1ps/1ps      :)
