Dra92
Define the required delay routine
Hi every one
I want to know, how can I define the required delay routine and ISE finds the paths can meet my defined delay?
I want to find some routes that generate pre-defined values of delay in my circuit.
drjohnsmith
I have not manually placed in ISE for a good few decades,
   there are plenty of references on line
e.g. https://www.xilinx.com/support/documentation/sw_manuals/help/iseguide/mergedProjects/fpga_editor/html/fe_df_placing_and_routing_critical_components.htm
A good place to start would be a search on how to create an oscillator in an FPGA
    the problems they have are the same as you will find,
    how to disable circuit optimisatoin, how to constrain and lock parts in place
   something like this
https://forums.xilinx.com/t5/Other-FPGA-Architecture/How-to-implement-a-ring-oscillator-with-routings-of-FPGA-Where/td-p/768444
drjohnsmith
I think you are looking in the wrong direction,
There is no way in FPGAs to define a set delay to be achieved in a path,
    the tools expect a maximum delay parameter and work to get under that
We have over the years , many people making oscillators on FPGAs,
     prinmeraly for Crypto designs
If you could give us some insight as to what your wanting to make, then we might be able to help.
Dra92
Thank you for this response.
I want to define a delay period, then ISE finds several different paths that can meet this conditional.
If there is a way to define these paths manually, it is also an acceptable way. I want to use wire are outside of SLICEs in my circuit. Find the delay of each of them approximately, consequently use them.
richardhead
Are you trying to define a minimum routing delay, or maximum routing delay?
Max routing delay would be defined automatically when you set a clock period. Specifying a minimum routing delay internally is basically not possible. Having any design with a required delay internally is likely not going to work or not be a sensible solution.
drjohnsmith
Sorry @Dra92 , thats not the way the tools work,
In FPGA designs we are interested in max delays, which specify how fast the circuit can work,
    and the tools take care of ensuring set up / hold times are meet .
FPGAs are basically a synchronous device, running off clocks.
You can place by hand individual "units" such a CLB's within the FPGA
    its done by those wanting to try to make oscillators out of gates
BUT , you have to understand the timing system in the FPGA.
    FPGAs speed varies depending upon Process, Voltage and temperature,
        Also different parts of the chip can be slightly faster than others,
       so even if you manage to measure the delay through one "unit" on one FPGA, The next FPGA it will be a different delay.
All of the PVT and placement variations are taken care of by the tools, when we specify the period ( frequency ) we want the circuit clocks to run at,
Dra92
Thank you for the comprehensive response; I got what you mean.
Is there any way to manually define paths from one point to the other point? Of course, they must be out of SLICEs, and between the CLBs? Then I find the max delay of these several paths as you told me.
PS: I mean from "manually" is such as when we use the primitives in SLICE.
drjohnsmith
   something like this
Dra92
  I followed the instruction that you gave me. There is one problem; the manually option is disable. Do you know the reason ?
I want to find several different paths between a carry-chain and a flip flop.
drjohnsmith
No is easy answer
What is your aim here ?
Dra92
I want to define two or more paths between carry-chain and flip-flop with a different maximum delay of routing. The primary variable of this design must be the routing delay in different paths. By changing each path, I want to change the delay between these two ones.
drjohnsmith
Some sort of random number generator.
Sorry, the tools are not designed to take an absolute timing to be meet , but a maximum they must get under.
  how far under that time is not possible to define.
If you do find a way,
please come back to the forums with your answer .
Dra92
Thanks for your help
