Delaying the External I/O clock in Zynq 7000 PL
WhatsApp Image 2019-06-27 at 4.23.43 PM.jpegRequired data Wave from clock
Re: Delaying the External I/O clock in Zynq 7000 PL
hi @lokeshwarangenn ,
Do you have further queries on this thread?
Else, close the thread by marking it as accepted solution.
hemangd
Hi All ,
I have one external clock to Zynq 7000 (PL)   from some image sesnor which is nearly 200 Mhz .with respect to same clock the sensor provides digital O/P for every pixels .Here attacehd photo have I/P Clock of 200Mhz(5ns)  to FPGA Ffrom sensor .DATA signal is coming from sensor as well .I need to make 1ns Delay of the input clock in FPGA HDL or Macro which is available in Vivado 2017.4.I need a Delayed clock as like in picture .Please any one suggest me the solutions fro this .Can I use the IODELAY2/3 for this kind of requirements .
Hi @lokeshwarangenn ,
You can use the  MMCM (Mixed Mode Clock Manager) to phase shift a clock signal, either by a fixed fraction of a clock period or by incremental amounts. Check for more info. on it. https://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf
IODELAY primitives are preffered to delay the data signals.
hemangd
hemangd
