Difference between IBUFG and BUFG clock
Hi all. I have implement a module in ISE with two clock inputs. One is 100M Hz and the other is 70M Hz. I set the timing constraint to 105M Hz and 73M Hz. There is no timing error during the implement.
Now when I try to creat a wrap of this module, which include DCM with BUFG (generate 100M Hz SRAM clock from 100M input clock) and PLL with BUFG (generate 70M Hz from 100M input clock). I set the timing constraint to 100M Hz for the input clock. When I run implement, the result is shocked. The timing report indicates that my module is only able to run at 16M Hz. I read the report and find that the clock skew is 3 ns.
I support there might be some difference between the IBUFG and BUFG. Could anyone please give me some advices?
Many thanks.
For the design with DCM/PLL, is the clock skew reported between the 100MHz and 70MHz clocks?
Cheers,
Jim
PS. IBUFG and BUFG are totally different things, but I must admit the names are confusing.
Cheers,
Jim
Thanks for your reply. The clock skew is between the 100MHz and 70MHz. I have modified my module by reducing the 70MHz. There is no timing error. However, could you please give me some suggestions if I don't reduce the 70MHz?
Many thanks.
Voyager
Voyager
An IBUFG drives a global clock net from an external pin.
A BUFG drives a global clock net from an internal signal.
As to your timing problem, I don't think you've given us quite enough data.
I don't know how you have things connected or which part you're using,
but you should be able to use a DCM to buffer the 100 MHz clock AND
create a 70 MHz clock.
Maybe you should post your clock logic and your constraints file.
John Providenza
