Different Phase Shift Modes in MMCM.
Hello.
I'm using Vivado 2018.2 with UltraScale FPGA.
I'm trying to create a MMCM with a IP CORE(Clocking Wizard).
I found a tap 'Phase Shift Mode' as the figure below.
What is a Phase Shift Mode in MMCM?
When I put a cursor in the Phase Shift Mode, below explanation appears.cursor.JPG
I couldn't understand the meaning of the explanation.
So I looked for the UltraScale Architecture Clocking Resources (UG572) to find out the Phase Shift Mode regarding WAVEFORM and LATENCY.
But I can't find out the Phase Shift Mode regarding WAVEFORM and LATENCY.
Does anybody have a clue?
Thanks for your help.
回复: Different Phase Shift Modes in MMCM.
That defines how the phase shift is modeled.
  • PHASESHIFT_MODE = WAVEFORM: phase shift modeled in the clock waveform (legacy)
  • PHASESHIFT_MODE = LATENCY: phase shift modeled in the PLL/MMCM latency
See UG906 on more information on the benefit of the latency mode.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug906-vivado-design-analysis.pdf
pg226, MMCM/PLL Phase Shift Modes
