czahner
Generate Post-Place & Route Static Timing fails without reason.
I am attempting to run the Generate Post-Place & Route Static Timing process. Every process up to that point completes successfully.  Here is the output from running the Generate Post-Place & Route Static Timing process:
Started : "Generate Post-Place & Route Static Timing".
Running trce...
Command Line: trce -intstyle ise -v 3 -s 3 -n 3 -fastpaths -xml XC6SLX150.twx XC6SLX150.ncd -o XC6SLX150.twr XC6SLX150.pcf -ucf XC6SLX150.ucf
Loading device for application Rf_Device from file '6slx150.nph' in environment
/opt/Xilinx/13.1/ISE_DS/ISE/.
   "XC6SLX150" is an NCD, version 3.2, device xc6slx150, package fgg676, speed
-3
Analysis completed Tue May  1 10:30:03 2012
Generating Report ...
Number of warnings: 0
Total time: 9 secs
Process "Generate Post-Place & Route Static Timing" failed
 After looking at this post, I verified my .xpi file contents:
PROGRAM=PAR
STATE=ROUTED
TIMESPECS_MET=YES
 Does anyone have further advice on how to get this process to complete?
czahner
Also, the FPGA is a Spartan-6. The OS is Red Hat.
bwade
I suggest that you take this question to the Timing Analysis forum which covers TRCE issues.
endab
What happens if you run TRCE from command line? You can more information on this in the the command line reference guide page 177.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/devref.pdf
qiufeng2
hello~
i meet the same question, and i do not kown why and how to manage it.
have you solved this question yet? if so, do you remeber how to solve it, or what's the reason?
my email is jfzhao04@gmail.com
thank you a lot.
sincererly
