ldm_gk
Hold Violations on negedge flops - how to solve?
Hi All,
I have Hold violations on the flops, which are driven by a negedge clock (rest flops are driven by the posedge clock). So, the negedge flops, which are driven by the posedge clocks, are receiving the hold violations.
What constraints (probably a multi-cycle path) should be applied to the negedge clock flops?
Thank you!
drjohnsmith
Can I ask , why are you using positive and negative edge flops ?
   doing so, tends to half the available set up times available , halving the available clock speed.
can you give us the block diagram of what your trying to do ?
     and your example code please,
avrumw
Expert
Expert
Are you sure about this?
It is virtually impossible to have a hold violation on a path from a rising edge flip-flop to a falling edge flip-flop.
Let's take the example of a 100MHz clock with a 50/50 duty cycle.
The rule for a setup check is "the capture edge is the edge of the clock at the destination flip-flop that occurs strictly after the launch edge at the source flip-flop". So for our 10ns clock on a path from rising edge to rising edge, the setup launch edge is at time 0 and the setup capture edge is at time 10. This makes sense.
For the hold time check the capture edge is "the active edge at the destination flip-flop that is one period earlier than the setup capture edge" (the rules are a bit more complicated for clocks with different frequencies). So for the same 10ns rising to rising path, the hold capture edge is the one before the hold capture edge; since the setup capture edge is at time 10ns, the hold capture edge is at time 0. This means "a change caused by the edge at the source flip-flop at time 0 must not propagate to the capture flip-flop before the capture edge (also at time 0)." In other words the data path delay must be greater than the clock skew (which makes sense).
Now look at the path from rising edge to falling edge. Using the rule for the setup check, the launch edge is the rising edge at time 0 and the capture edge is the falling edge at time 5ns. Again, this makes sense. Now the  hold rule above tells us that if the setup capture edge is the edge at 5ns, then the hold capture edge is the clock edge before that - the falling edge at time -5ns (NEGATIVE 5ns). Thus the hold check requires that the data change caused by the rising edge at time 0 must arrive strictly after the falling edge at the destination at time -5ns. Unless your clock skew is immense (greater than 5ns), this should be impossible.
So, again, are you sure this is the failure you are seeing?
Avrum
ldm_gk
So, what should the tool report in this situation? How will it report the HOLD check?
drjohnsmith
any feed back on why you want to do this ?
Ive not done negative / positive edge cross over since ISE in Xapp 861
This article seems to be similar, for vivado, which might cover what your after, as it has negatove and positive clock crossing and the constraints needed, and how to set them.
https://www.xilinx.com/support/documentation/application_notes/xapp1330-async-data-capture-hssio.pdf
dmitryl_home
As for feedback on why I need this... Actually one of my colleagues asked me this question and I did not have a clear answer... I did not ask him about the source of the question...
Anyway, thank you for your explanation, it's very clear.
BTW, where you took from the definitions for the capture edges for the Setup and Hold checks? Was this taken from the Xilinx docs? Could you please provide a reference for the definitions?
drjohnsmith
my apologies @dmitryl_home
   I missed that your not a new person to the forums ,
        We get so many people with I must do this and cant'
             that when I see a less than normal way of doing things question, the first thing I as myself is why ,
Glad the xilinx docs docs helped ,
dmitryl_home
Why cannot I find a way to mark Avrum's post as the solution? Where is the button?
bruce_karaffa
You are not the original poster.  Only the OP (or an administrator) may mark a post as the solution.
