Hold time violation around a PLL with two masters in clock that can't be run at the same time
Hello ,
I'm not a expert in the subject of fixing hold time violations , so I need help .
After synthesis the timing report shows me a lot of hold time violations between two generated clocks : o_CLOCK1x and o_CLOCK1x_1 .
After a report_clock , I found that these two clocks can't run at the same time .
o_CLOCK1x is a PLL's output when the master clock is Top_Xapp1249_inst/SDI/GTX_Rx/gtxe2_i/RXOUTCLK and o_CLOCK1x_1 is the same PLL's output when the master clock is i_ANA_CLK .
At the input of this PLL , there is a MUX_CLK between these two master clocks .
So I try the following contraint :
set_clock_groups -physically_exclusive -group o_CLK1x_1 -group o_CLK1x
but this contraint do not reduce the total of the number of Hold failing endpoints .
I try  the following contraints too :
set_clock_groups -name Groupe_3 -physically_exclusive -group [get_clocks Top_Xapp1249_inst/SDI/GTX_Rx/gtxe2_i/RXOUTCLK] -group [get_clocks -of_objects [get_pin TOP_HDMI_SDI_ANA_inst/GESTION_CLKs_inst/PLL_SP_inst/PLLE2_BASE_inst/CLKOUT0] -filter {IS_GENERATED && MASTER_CLOCK == i_ANA_CLK}]
set_clock_groups -name Groupe_6 -physically_exclusive -group [get_clocks i_ANA_CLK] -group [get_clocks -of_objects [get_pins TOP_HDMI_SDI_ANA_inst/GESTION_CLKs_inst/PLL_SP_inst/PLLE2_BASE_inst/CLKOUT0] -filter {IS_GENERATED && MASTER_CLOCK == Top_Xapp1249_inst/SDI/GTX_Rx/gtxe2_i/RXOUTCLK}]
but these contraints do not reduce the total of the number of Hold failing endpoints .
What is the contraint I have to write to reduce this number ?
Thanks in advance
Alex
Hi @watari,
Thank you for your prompt reply .
I just try this following contraint :
set_clock_groups -physically_exclusive -group [get_clocks I_3] -group [get_clocks I_2]
I do the same for the all CLKs that there is no interaction and the number of the Hold failing Endpoints falls to 46 after synthesis .
This number falls to 0 after implementation .
Good news and thanks for this support .
Alex
I try the following and the number of total decrease from 1188 to 261 . Do you confirm that is the right contraint I have to write?
set_clock_groups -name Groupe_5 -physically_exclusive -group [get_clocks -of_objects [get_pins TOP_HDMI_SDI_ANA_inst/GESTION_CLKs_inst/PLL_SP_inst/PLLE2_BASE_inst/CLKOUT0] -filter {IS_GENERATED && MASTER_CLOCK == Top_Xapp1249_inst/SDI/GTX_Rx/gtxe2_i/RXOUTCLK}] -group [get_clocks -of_objects [get_pins TOP_HDMI_SDI_ANA_inst/GESTION_CLKs_inst/PLL_SP_inst/PLLE2_BASE_inst/CLKOUT0] -filter {IS_GENERATED && MASTER_CLOCK == i_ANA_CLK}]
Alex
Hi @alectronic
I'm not sure.
But this is not correct.
Maybe here is correct description.
set_clock_groups -physically_exclusive -group [get_clocks o_CLK1x_1] -group [get_clocks o_CLK1x]
Would you try it ?
Best regards,
Now I want to have a look on the hold time violations between I_3 and I_2 .
The synthesis report :
And the clock report :
As you can see , the master clocks is two different PLL's outputs , the PLL I spoke about in my first post .
I tried the following contraint :
set_clock_groups -name Groupe_5 -physically_exclusive -group [get_clocks -of_objects [get_pins TOP_HDMI_SDI_ANA_inst/TOP_OUTPUT_inst/top4_Tx_inst/clkgen/loop8.tx_mmcm_adv_inst/CLKIN1] -filter {IS_GENERATED && MASTER_CLOCK == o_CLK1x}] -group [get_clocks -of_objects [get_pins TOP_HDMI_SDI_ANA_inst/TOP_OUTPUT_inst/top4_Tx_inst/clkgen/loop8.tx_mmcm_adv_inst/CLKIN1] -filter {IS_GENERATED && MASTER_CLOCK == o_CLKdiv2}]
but in the TCL Console there was displayed the following warning :
WARNING: [Vivado 12-1008] No clocks found for command 'get_clocks -of_objects [get_pins TOP_HDMI_SDI_ANA_inst/TOP_OUTPUT_inst/top4_Tx_inst/clkgen/loop8.tx_mmcm_adv_inst/CLKIN1] -filter {IS_GENERATED && MASTER_CLOCK == o_CLK1x}'.
Resolution: Verify the create_clock command was called to create the clock object before it is referenced.
WARNING: [Vivado 12-1008] No clocks found for command 'get_clocks -of_objects [get_pins TOP_HDMI_SDI_ANA_inst/TOP_OUTPUT_inst/top4_Tx_inst/clkgen/loop8.tx_mmcm_adv_inst/CLKIN1] -filter {IS_GENERATED && MASTER_CLOCK == o_CLKdiv2}'.
How can I create these two generated clocks : o_CLCK1x  and o_CLKdiv2  coming from two differents output of a PLL?
Thanks in advance .
Alex
hi @watari,
Thanks for your reply .
I tried the last contraint you suggested me and the number of failing endpoints  is decreased  from 1188 to 261 , the same as the contraint I have suggested .
Please could you have a look on me last message regarding ""create clocks from PLL's output" ?
Thanks in advance .
Alex
Hello ,
With several '' set clock_group - physically_exclusive '' contraints , the number of failing endpoints decrease to 46 .
I can't do anything now . Right ? (There is no more clock's domain crossing)  .
Hope that there is no time violation after implementation .
Thanks in advance .
Alex
Hi @alectronic
I'd like to confirm your current clock settings.
Would you share me the result of report_clocks ?
I think that you don't need like complex setting and you can describe more simple constraints.
Best regards,
Best regards,
Hi @watari,
Please find attached the file .
Alex
Hi @alectronic
Unfortunetly, Vivado does not recognize what you describe. (Refer the result of "report_clocks" command. line from 4 to 61).
It means that you can use these clock settins at get_clocks command.
In this case, there are two solution.
Solution 1)
Change location of clock setting from your description to ex. I_2.
Solution 2)
I'm not sure. But I suggest using get_object command instead of -of_objects.
Because of "get_clocks" command requests clock object.
Best regards,
[get_clocks [get_objects [get_pins TOP_HDMI_SDI_ANA_inst/TOP_OUTPUT_inst/top4_Tx_inst/clkgen/loop8.tx_mmcm_adv_inst/CLKIN1] -filter {IS_GENERATED && MASTER_CLOCK == o_CLK1x}]]
Hi @watari,
Alex
