How can I get Timing report in Vivado?
Always I get N/A in several simple VHDL codes. I get Power report after the Synthesis stage, but Timing.
Thanks a lot!
Guide
Guide
Re: How can I get Timing report in Vivado?
The report you show is a timing summary. If there are only "NA" in the table, this means that you have no constraints, and hence there is nothing to report.
You must properly constrain your design...
Avrum
