Anonymous
Not applicable
How to apply a constraint MY_Peripheral_clk_in from DCM_out_clk
Hello all,
I have XPS 10.1 and I did not edit my ucf before.
I have an NPI based peripheral connected to the mpmc.
I must connect the NPI_clk to the 125 MHz clock.
 so I edited my MHS
 /////////////// clock_generator ////////////
PORT CLKOUT1 = DDR2_SDRAM_mpmc_clk_s
/////////////////// mpmc ///////////////////
 PORT MPMC_Clk0 = DDR2_SDRAM_mpmc_clk_s
///////////////// MY_NPI_Peripheral //////////////////
 PORT NPI_clk = DDR2_SDRAM_mpmc_clk_s
When I synthesise the system, generate a report, i find the NPI_clk has a max of 104 MHz only!
 How do I add a timing constraint to fix this issue?
My peripheral does not operate on real FPGA, data seems to be corrupted.
Thanks in advance,
Tarek
Hi Tarek,
when you connected NPI_clk to  DDR2_SDRAM_mpmc_clk_s, you automatically constrained it, because there is a PERIOD constraint attached to the DDR2_SDRAM_mpmc_clk_s.
I think you should try to optimize your peripheral.
Maybe add more pipeline stages before the NPI port or something.
Message Edited by ivan.mironenko on 11-02-2009 10:26 PM
Anonymous
Not applicable
You could create a new timing group, only including the NPI_clk, then apply a new PERIOD constraint to that group, and it will overwrite the original one.
You may tighten the constraint value.
Anonymous
Not applicable
Can you specify how to do this?
I'm stuck in this issue for two weeks now.
Thanks in advance,
Tarek
