Newbie bbean
How to associate clock pin with non-bus pin
Hi all,
I have a custom IP block with CLK_X and DATA_X[27:0] input pins. How do I associate the CLK_X clock pin with the DATA_X pin?
Note: I can't make this a bus interface and use the ASSOCIATED_BUSIF property because in the larger project the pins are connected directly to board gpios.
Voyager
Voyager
Re: How to associate clock pin with non-bus pin
The menu selection you reference is a bit of a distraction. One doesn't associate a clock with a signal/port/interface; one associates a bus interface with a clock. The effect of the menu selection is to put the name of the bus interface (you selected before pressing the right mouse button) in the list of bus interfaces pertaining to the ASSOCIATED_BUSIF parameter of the selected clock.
That said, I'm still having a hard time seeing your dilemma. Pack the data port into a "data_rtl" bus interface, and you'll be able to associate that interface with the clock.
The instantiated IP should have an ordinary pin:
-Joe G.
Voyager
Voyager
You sort-of already made it into a 'bus' when you combined 28 signals into one vector...
As an alternative, you can create 28, separate 1-bit-wide 'bus' interfaces (DATA_X0 through DATA_X27), and associate each one of them with the clock.
-Joe G.
Newbie bbean
I agree DATA_X[27:0] is a 'vector' but not a 'bus'. What I mean by a bus is a Vivado-specific definition that gets applied when packaging the IP, selecting one or more ports, opening the context menu with right click, and choosing "Add Bus Interface...". For such bus interfaces, you can then right click on them and choose "Associate Clocks...".
What I am hoping someone will be able to tell me is how to right click on any port, bus interface or not, and choose "Associate Clocks..." (this option is currently grayed out for me).
Voyager
Voyager
-Joe G.
Voyager
Voyager
(continued...)
Even if it doesn't, you should be able to access the port by 'expanding' the interface pin:
-Joe G.
Voyager
Voyager
P.S. Be careful with that right-button menu. When I tried it, the bus interface was incorrectly connected to the clock as ASSOCIATED_RESET, instead of ASSOCIATED_BUSIF. (Vivado 17.2) I usually edit the CLK interface myself, and update the parameters by hand.
Newbie bbean
Creating "data" buses for the pins works, and then I could use the ASSOCIATED_BUSIF property on the clock pins.
Ultimately, however, this ended up not being my problem. Instead, my problem was the source of the clocks, which came into the PicoZed on a single pin, and so couldn't take advantage of the internal clocking structure on the fabric. I got around this by using FIFOs to cross clock domains with my synchronous incoming data as the first step so that the external clock source was relied on as minimally as possible.
